KraftWerks C38 Supercharger Kit FAQ Thread
Old May 22, 2017 | 05:22 PM
  #191
Tech2uned's Avatar
In the instructions it's recommended to do so. With the 30mm upgrade I took out the bolt and nearly smoothed down the that entire area.
Old May 23, 2017 | 09:15 AM
  #192
beaudin223's Avatar
good info here
Old May 23, 2017 | 09:26 AM
  #193
Akkmednoseflem's Avatar
Originally Posted by s2000ellier
Anyone have the issue where the crank pulley hits the steering rack bolt? Is it just worn engine mounts? Did anyone grind some of the bolt off the steering rack?
I had to grind a bunch off of the steering rack to get it to fit. Whenever I change the belt, its a very tight squeeze to get it around the crank pulley.
Old May 26, 2017 | 08:03 PM
  #194
kdurning's Avatar
Sounds like the "fix" might be something LHT is doing that is not in the instructions. I have not heard of anyone that had them install it having these issues. if you have please chime in.
Old May 27, 2017 | 12:36 PM
  #195
s2000ellier's Avatar
what a crappy design, how are you guys evening torquing the crank bolt since the OEM tool doesn't fit the stupid pulley?
Old May 27, 2017 | 08:31 PM
  #196
terriakee's Avatar
Question about the 30mm race kit. Are all the pulleys the same size? Or different diameter like the 20mm pulleys
Old May 28, 2017 | 07:43 AM
  #197
Anyone know where to buy a replacement cogged belt? Mine just snapped
Old May 28, 2017 | 02:30 PM
  #198
terriakee's Avatar
order from kraftwerks
Old May 28, 2017 | 02:45 PM
  #199
i dont see one for the s2000 on their site just the one for the BRZ/FRS
Old May 28, 2017 | 03:25 PM
  #200
mmhm's Avatar
https://kraftwerksusa.com/supercharg...t-compact.html
