Kraftwerks SC inbound, advice would be helpful.
Yeah now that you mention it, that's in interesting point. A friend of mine in the local s2000 club was one of the first to beta test the skunk 2 header. He ask me to help him tune it, so I asked him strait up what the afr was registering after he bolted it on compared stock header, and when he said it ran rich across the board, I told hi to return it, not worth bothering with.
LHT isn't the only place that was peddling this header. Moddiction was as well and King motorsports, redline360, and some other lesser known guys. I removed my berk due to fitment issues and returned it and installed the skunk2 because of a recommendation at the time by moddiction prior to his demise and the fit was immaculate and 4 years later I have still had zero issues.
I could understand thinking the header is junk for a bunch of other reasons. But confused as to why this would be a reason. For starters something of that nature should have the car tuned once installed, secondly if I had to pick between running leach and rich I would much rather run rich that risk detonation, and third the alpha was specifically designed around forced induction cars, so again, until properly tuned I don't see an issue with a car running rich
also, if it was really running that rich, it would trigger a cel. So it still must have been within honda's desired range
or the fact that headers cool the exhaust gas more (surface area) and locate the O2s further downstream. A cold O2 that went to sleep looks like a lean O2. So the PCM throws fuel at the problem.
Much more likely the skunk header that was used to test on my buddies car simply didint flow as well as stock. For anyone with a wideband, this is a simple strait to the point test for your breathing bolt on's in question. If the car goes rich at a particular point in the rpm compared to where it was before the bolt on, it simply is losing efficiency and your going to yield less power to pull fuel to tune for it. Its really very simple when you get to basic heart of engines and flow, which is less fuel, less power - no matter how you dress it up.
No, these points would be extremely unlikely. Not sure what your basing this on or if it just sounds good in your head. A 02 pickup point to read afr further down away from the combustion source reads leaner anyway, not richer. A properly reading tail sniffer on your local dyno reads .5 leaner then if picking up at the test pipe or header collector via wideband sensor. You can verify this.
im not trying to start an argument about it but at least on he FI side I have seen side by side in person dynos with noticable gains with a skunk2 vs stock on a kw kit and on a comptech kit.
I've also never seen a tuner use a tailpipe sniffer, all the tune sessions Ive gone to either used the aftermarket a/f already installed or I have seen them install a a/f sensor in the rear 02 location and set it up to an external reader. due to the inaccuracies of a sniffer in general
maybe i didnt communicate my point adequately... if a sensor further away reads leaner than the computer could be compensating adding more fuel for it to run richer. how do you know his readings werent after the computer attempted to counter an initial lean reading?
If you start altering the cam timing, valve and port sizing etc then an altercation in the header design to match flow character in the rpm you want to see the most efficiency would yield something. I'm not saying there isn't a aftermarket header out there that doesn't outperform the oem header somewhere in the rpm range either, just suspect of the Skunk based on what I said before. Possible the design was altered after the fact as well because of what we and other seen with it, don't know. But I will tell you that unless you are replacing a total pos cast iron manifold or poor design header, aftermarket almost always trades one part of the powerband for another, so there is a compromise. You want more low end and sacrifice top end or vice versa. Turbo on the other hand is entirely different animal when adapted to our NA engine. It doesn't even have a header, and no Exhaust is the best, as the turbo itself becomes sole flow and choke point.
And your good, i'm not trying to be confrontational at all either, just do my part to get proper information out there as I see it and not cause any confusion.
To add to the discussion, if the speculated circumstances did exist, where an O2 happened to be located further downstream than the oem design, and thus the O2 reads leaner than it should (than it would have in oem location), and thus the ecu adds more fuel than it should to try and achieve stoich (but in fact adding too much and resulting in rich), and ignoring open loop, than my question is...
From where is the guy with the Skunk header reading his afr ratio to determine (correctly or incorrectly) that its running too rich?
Wouldn't it be the same O2 sensor that is too far downstream? Wouldn't he see the same afr the ecu is seeing from the same sensor?
So then he wouldn't even know the car is running too rich, as he'd be fooled just like the ecu was.
So then he wouldn't be telling Junky that his car was running too rich after installing the header (if the issue was O2 sensor location and not header that flows worse than stock).
Thus the theory that maybe its not the header design but O2 location would seem to have another reason for the theory to not hold up to scrutiny.
