larger radiator
Old Feb 17, 2009 | 09:02 AM
roi's Avatar
roi
Default larger radiator
How important is it to have a larger radiator for a street car with a plan of 650whp
can i get away with the OEM one
Old Feb 17, 2009 | 09:10 AM
ArchAngel2K's Avatar
just to keep it safe go with a bigger radiator like a koyo that always works.
just know it wouldnt hurt
Old Feb 17, 2009 | 10:20 AM
nightcrawler7188's Avatar
i've seen people on here running that much power with stock radiators...but of course a larger one couldn't hurt
Old Feb 17, 2009 | 10:36 AM
kutsujula's Avatar
im running a koyo/fal fan setup. im currently trying to sell it though. Im going to be moving to a different setup now.
Old Feb 17, 2009 | 11:00 AM
roi's Avatar
roi
Are you not happy with it?
What setup ?
Old Feb 17, 2009 | 11:46 AM
dsddcd's Avatar
https://www.s2ki.com/forums/index.php?showtopic=656332
Old Feb 17, 2009 | 12:04 PM
kutsujula's Avatar
What setup ?
No I need a half size.
Old Feb 17, 2009 | 12:21 PM
GDM S2K's Avatar
im running a mishimoto rad with 2 12 inch mishimoto fans, im running 10-15 degrees cooler
Old Feb 17, 2009 | 12:46 PM
DesertWanderer's Avatar
I am running a Visteon dual core radiator modified for 06+ fan switch and relocated AC condensor, custom aluminum fan shroud, SPAL fans. The fans flow so well that when they come on in traffic they are only on for a very brief period of time.
This radiator upgrade became necessary when I upgraded (doubled the area of) my Setrab cooler for my Rotrex supercharger. Since the Setrab is situated in front of the radiator my engine temps rose more than I would like with the stock radiator. The Visteon and the improved fans and aluminum shroud have more than solved the problem.
I also have a 330 mm long MOCAL oil cooler mounted on the crossmember between the radiator and the engine. This has helped a lot as well!
Old Feb 17, 2009 | 12:54 PM
Forgot to add, I run 163 - 165 degrees on the highway, max of 202 degrees in traffic. (Fahrenheit for the International crowd!) This setup works great, I have 64,000 miles on my 2007, about 4,000 miles with the dual core radiator.
Enjoy!
