Lean idle/misfire issue
Old Oct 13, 2010 | 08:24 PM
mosmoe's Avatar
Default Lean idle/misfire issue
I just bought a 2003 s2k with the comptech s/c kit. Everything was fine for about 1,500 miles, then the idle started to get rough. I took it straight home and parked it. Currently I have a misfire code, it will idle fine at around 14.7a/f for a little while, then the idle gets rough and the a/f gauge reads --- then in the 16 to 17 range. Fuel pressure at idle is a steady 55psi.
I am very mechanically inclined, but I am used to working on Audi's, so I am not familiar with the common s/c s2k issues and fixes.
Ideas?
Old Oct 13, 2010 | 08:34 PM
s2000maniac's Avatar
well pull your sparks plugs and check them out
Old Oct 14, 2010 | 05:40 AM
mosmoe's Avatar
Compression:
1-205
2-212
3-202
4-210
Plug pics on the way
Old Oct 14, 2010 | 06:18 AM
mosmoe's Avatar
Old Oct 14, 2010 | 07:19 AM
the plugs look normal... put some new plugs in and see if that fixes the problem. pull your fuel injectors and make sure they are clean and not full of carbon etc.... if the problem still comes on then move on to valve adjustment.
Old Oct 14, 2010 | 07:21 AM
mosmoe's Avatar
Ok. I will check the fuel injectors. Should I check the idle air controller?
Old Oct 14, 2010 | 07:44 AM
mosmoe's Avatar
Old Oct 14, 2010 | 07:45 AM
mosmoe's Avatar
What are the suggested plugs for an s2k w/ sc?
Old Oct 14, 2010 | 08:55 AM
chef-j's Avatar
NGK. But since yours is boost, should be 1step colder. Check with FI section guys.
Old Oct 14, 2010 | 09:18 AM
ngk iridiums should be fine.
