Lets talk compression and boost
Old Feb 8, 2009 | 06:37 PM
candymanjl's Avatar
the biggest benefit of the lower compression is lowering the peak cylinder pressure, the amount of pressure in the cylinder when the spark happens. lower peak pressure (pressure ratio) the less stress on the whole motor, the happier everything will be
Old Feb 8, 2009 | 06:41 PM
candymanjl's Avatar
Originally Posted by HvRRZ,Feb 8 2009, 09:33 PM
I'm sure having the AEM Methanold set up helps a lot. How is your experience with it thus far? How often must you refill the tank? I know that does depend somewhat on how the car is driven.
My only fear with that system is if there is a malfunction and it stops working...then hope the engine doesn't go boom. Is there a fail safe in the system? say switching to a second tune if it fails.
the AEM meth kit when set up right has a few failsafes...
http://www.aempower.com/ViewCategory...CategoryID=120
Old Feb 8, 2009 | 06:51 PM
HvRRZ's Avatar
awesome link! thanks.
what an amazing system, and to think it costs so little. I wonder why so many would rather go with the aquamist unit...
Old Feb 8, 2009 | 07:09 PM
Sideways's Avatar
Originally Posted by HvRRZ,Feb 8 2009, 07:29 PM
Sideways I cannot maximize the image...it seems my membership has run out :/
From the looks of it the difference is very minimal throughout the power band as far as hp. Looks like the biggest difference is seen in bottom end torque, which is to be expected. Were these dynos done on the same pulley?
From your experience would you recommend I go with a slightly lower compression ratio if I plan to boost 10psi, and not any higher? I think the 2.4L will more then make up for the slight drop in torque if I do, but then again if it's not really necessary then why bother.
The following is a best estimate with my poor eyesight.
RPM : difference in ft lbs
3000 : 9
4000 : 9
5000 :14
6000 :15
7000 :17
8000 : 8
8300 : 3.8
9000 : 6
It appears the difference at the peak torque 8300 rpm is smaller than at both 8000 and 9000 rpm.
I did not look back and upped the boost soon after that dyno.
If you are running a stock block then do the boost you want. If you are building a 2.4 FI motor then lower the compression.
Old Feb 8, 2009 | 07:44 PM
HvRRZ's Avatar
Sideways thank you. The information you've shown is exactly what I wanted to see. Some hard evidence of exactly what effects there will be when the compression ratio is lowered, and the boost is kept the same. It doesn't hurt that you are also supercharged which is why I'm asking all this. I'm still surprised that the effects were so minimal, but also glad to hear of it.
Old Feb 8, 2009 | 08:55 PM
Artisan7471's Avatar
Sideways how much boost where you running on those dyno charts? And how much are you running now?
Old Feb 9, 2009 | 12:52 AM
stena's Avatar
is there a tread or info to AEM water injection? i am thinking of getting one so people who already went trough the pain of install and modify would help a lot.
Old Feb 9, 2009 | 06:03 AM
HvRRZ's Avatar
Water/Meth Thread
Old Feb 9, 2009 | 06:19 AM
slimjim8201's Avatar
This may help...
Power vs Boost Pressure Discussion
Old Feb 9, 2009 | 06:27 AM
JoeyBalls's Avatar
The Tuner can set up some failsafes, but there is a little green LED light that comes on when you start to spray (brightens depending on the flow), and it is constantly testing itself, I had a loose wire and it was blinking so I new not to BOOST etc........ It also blinks when it is low on fluid. I fill it up once per Fill up at teh gas station, but even then there is more left, I just top it off to be safe. The only annoying think is BLUE DYE around the BOV area
I did a little experiment this fall......
I was stuck in traffic so I decided I would take the back roads and open her up. Before I did this I popped my hood and burned my hand on the charge pipe and intake manifold, I wanted to feel how hot it was, it was BURNING hot, so I get back in the car and go WOT winding out the gears to about 100MPH then pull over and pop the hood again.............The charge Pipe and Intake manifold, as well as the Intake side of the Valve cover were COLD!!!!!!!!!, I don't mean like room temp, it was COLD
Here is my INSTALL WRITE-UP
https://www.s2ki.com/forums/index.php?showt...&#entry14425116
