Likely power increase from 7psi to 9-10psi
Old Sep 19, 2010 | 05:55 AM
s2konroids's Avatar
Default Likely power increase from 7psi to 9-10psi
Guys thinking of going for a 9 or 10 psi pulley up from 7psi.
I have the following bolt ons etc in my signature, may run a greddy emanage with rc550 or 650 injectors.
Would I need an aftermarket clutch? Launches are not my profession thing plus i only up the car 20% of the time.
She's currently running at just over 350 bhp @flywheel.
What power increase would i see?
Thanks
Old Sep 19, 2010 | 06:00 AM
ChefJ's Avatar
30-40 or so.
Old Sep 19, 2010 | 06:03 AM
Revenge's Avatar
I would say 10-12 hp per psi
Old Sep 19, 2010 | 06:04 AM
Enlightened's Avatar
or 15 hp per 1 psi
Old Sep 19, 2010 | 06:11 AM
s2konroids's Avatar
Thanks chaps so it's possible with a bit of luck 400bhp
Old Sep 19, 2010 | 06:29 AM
AusS2000's Avatar
You'll be in the market for a clutch pretty soon.
Old Sep 19, 2010 | 06:34 AM
s2konroids's Avatar
With 7psi you mean?
It will be a ball ache to install
Old Sep 19, 2010 | 06:42 AM
Sportster's Avatar
Even with 10psi if you are not power shifting or launching you will not need a clutch although one is recommended.
Old Sep 19, 2010 | 08:00 AM
Sideways's Avatar
I have seen anywhere from 12 to 17 rwhp per psi depending on how it is set up and add ons.
When you get your next dyno at higher boost note the exact pressure and horsepower change.
You can figure how much power you will make going up in boost from there if you have no other changes. With a supercharger you must remain within the efficiency range and if you go beyond it the power drops off quickly.
Old Sep 19, 2010 | 08:39 AM
Blown's Avatar
Banned
[QUOTE=Sideways,Sep 19 2010, 08:00 AM]I have seen anywhere from 12 to 17 rwhp per psi depending on how it is set up and add ons.
