Long drive with boost
Old Feb 4, 2026 | 09:07 PM
jvan's Avatar
Default Long drive with boost
I just bought a turbo s2000 after my stock s2000 broke down. I’d like to take it (as my only car currently) on a 4 hour drive but I’m super paranoid. Is there anything I should do to prepare or stuff to bring. It was tuned to around 650hp but now it’s tuned down to 450 since it’s my daily for the time being. I’m just worried about it blowing up or something going wrong since I didn’t build it and don’t quite know everything about it.
specifics Dual Turbo smart 44mm wastegates
Tial 50mm blowoff valve
Pulsar 6266 turbo
King performance turbo manifold
KP 2.4 stroker engine
KP 11.1 comp piston kit
KP spec upgraded wrist pins
KP spec 2.4 rods/ ARP 2000 rod bolts
KP race rod, main and thrust bearing set
KP sleeved block
KP race head packetae
KP Valvetrain kit
KP port/polish head
Clutch masters twin disc clutch
FIC 1650CC injectors
Full throttle fuel rail
Full throttle fuel pump
Aero motive 1000 fuel pressure regulator
Old Feb 6, 2026 | 11:58 AM
SilentWrath*'s Avatar
Assuming the engine is healthy and the tune is solid it shouldn't be an issue. It's not like you're beating on it in full boost for the entire trip.
What ecu are you using? Safeguards set up? What sensors do you have? Wideband o2? Oil pressure? Etc...
Old Feb 6, 2026 | 12:14 PM
jvan's Avatar
engine is at 90k miles and I changed all the fluids when I got it so engine is in tip top shape. AEM series 2 ecu, AEM wideband/ethanol/boost gauge
Old Feb 7, 2026 | 05:38 AM
Chuck S's Avatar
I've heard rumors you can drive a "boosted" car without holding the accelerator to the floor at no more stress on the engine and drive trail as any other car. Hard but not impossible to do and less fun.
-- Chuck
Old Feb 8, 2026 | 08:17 PM
Ian300D's Avatar
I attempted to drive a turbo s2000 about 1k miles across couple states. Halfway home oil return line failed out of no where and had to tow rest of way home.
Turbo car doesn't mean long drives are out of the question.
Old Feb 9, 2026 | 06:03 AM
SlowTeg's Avatar
Ya just depends on your risk tolerance. If you're willing to buy someone else's project car as your daily you sound pretty brave to me to begin with. I would give the car a good once over to check for anything loose/etc and bring some tools with you. Ultimately like Ian said, you never know what's going to happen.
Old Feb 9, 2026 | 07:39 AM
Bullwings's Avatar
Sounds expensive
Old Feb 9, 2026 | 09:15 AM
R00567's Avatar
Pulsar 6266 turbo
KP sleeved block
KP Valvetrain kit
KP port/polish head
I did the same thing many moons ago in 2017 (purchased someone's previous project that was turbo). The owner was very honest about the car's status i.e. overheating among other things... he paid an unmentioned shop 12K$ to turbo the car... the install was poorly executed and corners were cut left and right. They ruined the car to the point the previous owner stopped driving it. Younger self thought they knew what they were getting into but at the same time I did not realize how awful the previous shop was (the car was a MY 07 with 27K miles on the clock).
The car attempted to light itself on fire multiple times (3) as well as a dump tube breaking off and overheating like heck (stock rad).
Here are some gems of advice:
  1. Not all people do shoddy work - also don't trust anything any one tells you (triple check everything related to the install).
  2. Try to not beat on it too much especially if you do not know the status of the tune etc.
  3. Have you gotten under the car to check if the oil lines etc are good to go / nothing is melting, rubbing or fraying? Losing an engine due to an oil line giving out or a wastegate boost reference line melting would be a very sad day.
  4. Take spare tools and fluids with you in case you find yourself in a predicament / pickle...
  5. Take a fire extinguisher with you as well (just to be safe, you never know).
  6. I would monitor you wide-band O2 and oil pressure if those metrics are available to you during the drive.
  7. Give the car breaks as much as you can and just monitor your engine vitals along the way.
  8. If you are anything like me - post tune - get the car home and then start going through the setup and make sure everything is buttoned up and is good to go.
  9. Did you check to see what the fuel system looks like? often times - even with the SOS wiring kit - the wiring that goes to power the pump is under-gunned for the task and will fail on you. Do you have supplies to Macguiver this or can you ensure that the wiring for your fuel pump is sorted before you travel?
Good luck + enjoy your new car!
project2k4
Jan 24, 2021 10:08 PM
ap2bruce
Oct 10, 2016 10:27 AM
conors2k
Dec 14, 2013 09:24 AM
anarchy187
Dec 8, 2011 04:55 PM
tranceporter
Jan 13, 2011 07:56 PM
