loosing boost?
Old Jun 22, 2006 | 06:14 PM
icemans2k02's Avatar
Default loosing boost?
I have an 02 with vortech supercharger and aftercooler. installed my boost gauge and noticed full boost is only 6 psi. I thought the vortech normally ran 7-8. i checked vaccum leaks of course there are no CELs thrown. So i dont know if maybe that is normal with some chargers. Also if the belt was slipping could you hear it?
Old Jun 22, 2006 | 07:07 PM
9kFever's Avatar
start by checking the belt
Old Jun 22, 2006 | 07:12 PM
revhi's Avatar
Which gear are you testing this in?
Old Jun 22, 2006 | 07:18 PM
ex-eclipse's Avatar
Is your boost gauge accurate?
Old Jun 23, 2006 | 07:11 AM
yea the gauge should be just because this was a preowned kit and the guy before told me that he was boosting 7.5. and i am testing this in all gears, i will roll in first then hit it hard all the way through third. everytime max psi is at 6
Old Jun 23, 2006 | 07:23 AM
Sideways's Avatar
First, check the belt for tightness. Do you know the steps in tightening the belt?
Old Jun 23, 2006 | 08:42 AM
yea i thihnk xviper posted a DIY on that, i will check.. question is if it is loose just a little will you hear it squeal?
Old Jun 23, 2006 | 08:48 AM
Sideways's Avatar
the answer is NO
Old Jun 23, 2006 | 03:01 PM
r_duff's Avatar
sideways, do share!
I remember comptech's thing was to tighten it as hard as u can push the tensioner pulley against the belt. After, they say you should only be able to move the belt no more than 1/4'' either way by the tensioner.
Is it possible to 'overtighten' a belt?
Old Jun 23, 2006 | 03:47 PM
Nhan's Avatar
Id like to know the steps in tightening a belt
