Love Fab oil return
Old Jun 13, 2005 | 03:25 PM
AusS2000's Avatar
Default Love Fab oil return
I'm waiting on my LoveFab manifold and turbo but in the mean time I'm doing prep work. I pulled the sump on the weekend and installed the 4 hole oil bolts (what a PITA no. 1 was!). I'm going to baffle the pan and install the oil return.
What I need to know is what size and type is the fitting and where does it go? Pictures would be ideal.
Old Jun 13, 2005 | 03:33 PM
AusS2000's Avatar
Here's a picture of the side of the sump:
Anyone want to play "Pin the oil return on the sump"? Just take the blindfold off first.
Old Jun 13, 2005 | 06:42 PM
Slows2k's Avatar
Iv'e seen em' right above the drain plug, and in the main cap girdle above it.
Old Jun 13, 2005 | 07:08 PM
herecomesboost's Avatar
Old Jun 13, 2005 | 07:15 PM
kane.s2k's Avatar
As high up as you can in the pan.
Old Jun 13, 2005 | 07:16 PM
AusS2000's Avatar
I'm sure there are several places I can put it but LoveFab is supplying the oil lines so I need to ensure that it will reach and has the right type of connection.
Old Jun 14, 2005 | 04:13 AM
RZFD's Avatar
Shoot cody a PM.
Old Jun 14, 2005 | 04:38 AM
AusS2000's Avatar
I have, but I suppose he's too busy actually making my kit and I won't argue with that.
Old Jun 14, 2005 | 07:04 AM
Tinker219's Avatar
the next "flat spot" toward the firewall from the oil drain line, all the way up as high as you can go without hitting the block, etc. MAKE SURE YOU DONT WELD THE FITTING ON UNDERNEATH AN OIL PAN BOLT!
And its a -10AN fitting, youll need a male weld-on bung, which we supply. If you dont need it, let me know as we can re-use them here...
Old Jun 14, 2005 | 07:55 AM
S2000_Europe's Avatar
Cody
if you have time Could you draw an X on the pic because I did not understand anything
