Low Boost out of Comptech
Old Jun 29, 2008 | 10:21 AM
bublik's Avatar
Default Low Boost out of Comptech
So im at a loss of knowing whats going on. Ill give you a bit of detail about the AP2:
Comptech Kit
Tuning by K Pro
750cc injectors
SOS 3.2" pulley
rest of supporting mods to make it work
So at first we tightened the belt on the supercharger pulley to 1/4" degree of deflection and thought that would do it since it was loose. Now, it doesnt seem to slip anymore but its only hitting 8.0-8.5 pounds of boost. The pulley is rated at 12.8lbs at 8K on the 2.2L. I have the aftercooler, so I know about .5 pounds are lost with that, but I just dont know what to do?
Any help would be great, because the car used to run at 12Lbs before but now just is horrible.
Eddie
Old Jun 29, 2008 | 11:51 AM
EriS2k's Avatar
Belt Worn out?
Belt Slippage?
Check your Conections in the Aftercooler
Old Jun 29, 2008 | 08:54 PM
bublik's Avatar
belt is not worn, maybe slipping not 100% sure.
Ill check the aftercooler
Old Jun 30, 2008 | 12:24 PM
EriS2k's Avatar
Any News?
Old Jun 30, 2008 | 04:18 PM
abv's Avatar
abv
check your BOV
Old Jun 30, 2008 | 08:39 PM
CourageOO7's Avatar
Originally Posted by abv,Jun 30 2008, 07:18 PM
check your BOV
For what? Obstructions?
Old Jun 30, 2008 | 09:12 PM
AusS2000's Avatar
Leaks
Old Jul 1, 2008 | 11:07 AM
abv's Avatar
abv
exactly leaks... you will loose boost
Old Jul 1, 2008 | 06:54 PM
CourageOO7's Avatar
How do you check a BOV for leaks? Check the internals for holes/gaps?
Old Jul 2, 2008 | 11:24 AM
bublik's Avatar
I took a look at the BOV, but, at the bottom of the BOV where a vacuum line goes, there is no hose?!? Is this normal for this setup because i've had a bosch bov and it had a vacuum line running to it.
Eddie
