low comp pistons or 3mm HG
Originally Posted by corners2fast4u,Oct 26 2007, 03:36 PM
If you are tying to squeeze 25-30PSI out of a GT3076 with a headgasket would you say thats safe for a DD?
Mine is only taken out on the weekends to beat up on the so called fast cars around these parts........I have yet to lose.
Spoolin are you running that much boost on a headgasket? Race fuel to prevent detonation and blowning the gasket? Or is that just to much boost for the headgasket to handle? Im just trying to figure out how much boost those 3mm headgaskets could handle fairly reliably with a good tune.
On normal premium gasoline, if you're only looking for power up to 500 rwhp, the hg is the best choice for convenience and price. If you want more than 500 rwhp, than building the block is probably the best choice unless you want to run race gas like spoolin does.
Originally Posted by Spoolin,Oct 26 2007, 12:39 PM
I wouldn't recommend it because you will have to always run race gas.
I would assume that the Inline-Pro 3mm HG is good for around 30 psi and race fuel on a very good tune. The stock engine with the 3mm HG, ARP headstuds, and race gas should be easily good for 600 whp.
Originally Posted by AirborneS2K,Oct 26 2007, 08:04 PM
How many of those 'fast cars' that you race are people's daily drivers and run 93 octane?
what are you doing to help control the heat? are you using the "updated" oil jet bolts?? just wondering i plan on installing them this weekend i have 01 and using P-fab manifold running 13psi with 3mm HG
