Mac solenoid clicks all the time now
Old Jun 18, 2012 | 08:22 AM
s2knoob89's Avatar
Originally Posted by gettin it
Sure have, you? i tried that.
Try harder. Second link
http://www.google.com/search?hl=en&c...EtUA4VYU&mvs=0
Old Jun 18, 2012 | 08:39 AM
gettin it's Avatar
Ok, i seen that one the other day, but the whole electrical info is misunderstanding. And then i seen another with the third port connected, and this diagram shows its not.
Old Jun 18, 2012 | 08:43 AM
s2knoob89's Avatar
One wire to pin d16 on the ecu and the other to any 12v source. Unless your running dual wastegates you should set it up like AEM says to.
Old Jun 18, 2012 | 09:00 AM
gettin it's Avatar
Ok great info. Ill connect everything within a few days, and thanks for the assistance. Last but not least, do it matter which wire goes to the pin? Im not near the noid right now so im not sure if its marked.
Old Jun 18, 2012 | 09:09 AM
s2knoob89's Avatar
Does not matter.
Old Jun 18, 2012 | 10:11 AM
CoolGuy094's Avatar
Originally Posted by s2knoob89
Does not matter.
God bless your patience s2knoob89, lol.
Old Jun 18, 2012 | 11:18 AM
spectacle's Avatar
Sorry to thread jack, but how do you install and run the vac. lines and power to the mac noid? I searched and seen a diagram how to run the vac lines but cant find it now.
BC wiring: https://www.s2ki.com/forums/index.php?showtopic=766169
Written for Kpro, but should be applicable to AEM as I believe you can use the same output.
Vacuum lines - on the solenoid port 1 goes to the boost reference from the turbo which should be t'd to the side/bottom port of your wastegate. Port 2 goes to the top port of your wastegate.
Old Jun 18, 2012 | 06:29 PM
mtber's Avatar
Originally Posted by spectacle
Originally Posted by mtber' timestamp='1339997747' post='21789778
Set the duty cycle to 0 where you don't want to hear it..
You may need to alter the WG Duty MIN to 0%
7 year lurker lol
Sup John!
Hey buddy. When are we going to go race the yaris?
That thing almost maxed out the old dyno, remember? hahaha
Old Jun 19, 2012 | 02:41 AM
gettin it's Avatar
Thanks again guys. Vac. lines ran last night, completting the wiring tonight hopefully.
Old Jun 20, 2012 | 05:37 AM
gettin it's Avatar
d16, where can i source a pin and plug from please?
