Magnus Intake manifold fitment issues
Old Oct 23, 2014 | 01:10 PM
mattie170's Avatar
Default Magnus Intake manifold fitment issues
Brought a magnus intake manifold from a guy that was building a drag car in the UK but he gave up so it was brand new and unused. It was originally purchased through kings performance. I have come to fit it to my newly built engine and it didn't fit. It was fouling on the top belt tensioner bolt and part of the alternator, I didn't have time to mess about sending it back etc so quickly modified it so it does fit (pic below).
What I want to know has anyone else had problems?
Old Oct 23, 2014 | 01:34 PM
Chance S2K's Avatar
Wow that's really odd... You'd figure if they charge $600 for an intake manifold that it would actually fit.
Old Oct 23, 2014 | 01:49 PM
riceball777's Avatar
I have not heard of many people with that manifold for the s2000.
Old Oct 23, 2014 | 07:37 PM
redboost10's Avatar
mine fit fine. that is odd. never had a problem with it. i would call magnus directly. kings will be no help.
Old Oct 24, 2014 | 12:57 AM
mattie170's Avatar
No point now calling them its on and hopefully working, I think the jig must of moved when welding it as the plenum chamber is at a different angle to the runners which in turn has pushed the bottom of the plenum closer to the floor resulting in major fouling. It seems most things I buy never fit straight on
Old Oct 24, 2014 | 04:08 PM
staylor725's Avatar
any picture's of the manifold mounted on the car?
Old May 17, 2016 | 07:07 PM
okaydel's Avatar
Old post but I'm here to report I had the same issue. I had to go with the hondata manifold spacer plus use a hex pan head bolt in order for it to fit. The flange for the OEM water outlet was also a major pain. Had to bend one of the outlets out of the way and the manifold was impossible to install using bolts because of the flange. Studs had to be used since you cant fit the bolts in where the flange is for the water outlet - only has enough room to fit a nut.
Old May 17, 2016 | 07:08 PM
okaydel's Avatar
After doing the install, I don't think I can recommend Magnus intake manifolds to anyone on here. Maybe our two were early prototypes or just poor QC/bad luck?
c32b
Sep 4, 2017 03:22 PM
Floppy
Jan 16, 2015 03:27 AM
Mustb18
Jun 11, 2012 10:38 AM
redap186
Apr 17, 2010 08:05 PM
08s2000CRbackinblack
Sep 22, 2008 06:41 PM
