Make an 06 motor work in AP1 w/ AEM EMS
Got an offer on a nice low miles F22 from an '06 DBW.
Does anyone know what needs to be swapped to make it work?
So far Ive discovered you need to swap the..
-valve cover
-intake manifold/ tb
-2 sensors (crank & something else)
Is there anything else? Are the senors easily accessible or do you have to start tearing the motor down?
thanks for the help
-valve cover
thanks for the help
Originally Posted by PsykotiK,Mar 10 2010, 01:48 PM
should be the exact same thing as the 04/05 f22c.. just swap out and use ur ap1 harness and get rid of the dbw components such as the tb and such and use ur ap1 stuff
Read about it here: https://www.s2ki.com/forums/index.php?showt...&#entry11923457
Originally Posted by 73Zero,Mar 10 2010, 02:45 PM
From what I've been told, it actually isn't that simple. The 06 and up AP2 cylinder heads are missing the air injection ports present in the 04-05 AP2 and 00-03 AP1 cylinder heads. Not sure if you could machine them in there or not.
Thats why they make block off plates.
Originally Posted by TRBOKEV,Mar 10 2010, 05:59 PM
You dont need those ports with AEM EMS...
I purchased the motor, after reading this thread & talking to a few locals it seems like it wont be that bad. https://www.s2ki.com/forums/index.ph...c=563105&st=25
Both motors will be on stands so swapping parts should be a breeze. We are already taking off the oil pan on the newer motor to tap the girdle, a few more bolts and the front cover comes off to change the pulsur & crank sensor.
Then it just swapping the cam wheels which I believe can be done without removing the cams. Install my valve cover, intake mani, fuel rail etc. Swap the harness over & its basically done.
