Man am I exhausted!
^I believe Phil's car is running a 63mm downpipe... Not sure on the exhaust diameter, but I think it was a 70mm... Mase designed the kit specifically for the smaller DP, I believe.
Not too sure about the physics of it, but I think a little bit of back pressure helps sometimes.
John
John
Originally Posted by S2oooNvegas,Dec 20 2008, 02:22 PM
nah, thats perfect. at 500 whp, single 3 inch is DONE. Dual 3 inch, on a V8 is done at 800 hp. so..400 hp per 3 inch pipe with muff.
So many guys on here are really pushing it, with 3 inch pipe on their turbo cars.
Pretty much all the big names on here, should have 4 inch.
My buds street driven nova, has dual 5 inch.
Supras don't swap into 4" until they are around 700.
Common misconception as is the fuel pump.
Standard walbro 255 will handle 600 hp aswell
Originally Posted by Kirpich,Dec 20 2008, 08:48 PM
NA + backpressure = good (torque down low)
FI + backpressure = bad (kills spool up time).
http://www.uucmotorwerks.com/html_product/...etorquemyth.htm
Originally Posted by Sellout,Dec 21 2008, 01:32 AM
Even in an N/A application, the old rule about backpressure is pure BS. No backpressure is absolutely always better, if you have a means to tune your car.
