Map sensor for 10-15 psi boost (flashpro)
Old Aug 25, 2016 | 09:57 AM
Alexander Startsev's Avatar
Default Map sensor for 10-15 psi boost (flashpro)
What would be a good one? Is AS336 2.8 bar sensor? Is it ok?
Old Aug 25, 2016 | 10:03 AM
Kenny_Stang's Avatar
I use the SoS 4 bar MAP sensor
Old Aug 25, 2016 | 10:14 AM
Memo6453's Avatar
^ I used the same one
Old Aug 28, 2016 | 03:13 PM
MorngWoodStewie's Avatar
The only problem with finding the "one" you want per you're application is sometimes there not as reliable as the more proven, reliable, durability ones you find, which are although made and reviewed as reliable are also made as a 4bar to fit everyone's application soo more sales. Get what u want and a tune, I think I read ur using flashpro so I would just shop for one on there drop down, and then get a tune
Old Aug 29, 2016 | 09:41 AM
ScienceofSpeed's Avatar
Former Sponsor
The Hondata and ScienceofSpeed 4 BAR MAP sensors use the same pressure transducer - they are interchangeable (ie. you can select "Hondata 4 BAR" from the drop down if you have our sensor).
Old Aug 29, 2016 | 01:31 PM
Cool!
