Mase Kit motor build help
Hello,
I just had a few questions about building my motor on my ap2 s2000. I currently have the Mase kit with the Precision 5857 turbo, kpro, 3" exhaust and 1000cc injectors. I want to see how much power i can get out from this mase kit. I believe someone told me it should be around 600-700 hp but I'm not too sure.
As for what I'm thinking of what i need is...
Pistons
Rods
Head-studs
valvesprings & Retainers
Valves
and/or maybe turbo cams.
I'm not sure if i should sleeve my block too. If so how big do you recommend?
If you have any recommendations what i need or don't need. Please let me know
Pistons
Rods
Head-studs
Valves
If no problems with your current block, use the SOS FRM compliant low compression pistons and just hammer on the stock block...
Big thread about these pistons in this section...
https://www.s2ki.com/forums/index.php?showtopic=805890
