Max Boost on stock engine with SC
Old Jun 2, 2008 | 05:48 PM
Jay-Z's Avatar
Default Max Boost on stock engine with SC
searching for max boost has on stock engine. I did the search but my eyes are spinnin from the off subject things im reading so please assist if you have solid answers.
I have an 02 vortech SC w/ aftercooler running at 11.77lbs of boost @ 8400RPM cutoff on the stock head as of now. What is the max boost i can safely use as this is my daily driver. The car was tuned by church automotive testing and shawn church says once i get my RC 650 injectors put in he can tune me up to 14lbs at 9krpms. He says ill be at about 420-430hp. Am i pushing it? Any input will be helpful. Thanks in advanced!!!
Old Jun 2, 2008 | 06:11 PM
Enthralled's Avatar
374WHP on stock injectors...SWEET!!
Old Jun 2, 2008 | 06:15 PM
DC5 RSX R's Avatar
Alot of a boosted daily driver is how you drive it but more boost will always tend to shorten the lifespan. 400 hp is quite a bit for a daily driven, high compression engine
Old Jun 2, 2008 | 06:20 PM
s2000442's Avatar
Read Sideways post on how to maximize the vortech supercharger...excellent post and should answer most of your questions, if not then PM him. I would say he is the resident expert on everything Vortech
https://www.s2ki.com/forums/index.php?showtopic=588363
Old Jun 2, 2008 | 06:25 PM
UberDuper's Avatar
AFAIK the vortech is a 5th injector setup. When you move to larger injectors, do you ditch the 5th supplied with the kit?
UD.
Old Jun 2, 2008 | 06:29 PM
Enthralled's Avatar
UD.
I did. btw this is only on the AP2 kits.
Old Jun 2, 2008 | 07:12 PM
9kFever's Avatar
Nice numbers...after about 12psi on the vortech you are starting to push it a bit. However, depending on how you drive it it should hold up.
Old Jun 2, 2008 | 07:13 PM
9kFever's Avatar
your not on stock injectors are you?
Old Jun 2, 2008 | 07:18 PM
Jay-Z's Avatar
Yes i am on stock injectors. Is that odd?
Old Jun 2, 2008 | 09:58 PM
ABCVTEC's Avatar
Not odd, impressive. I'm running lean on stock injectors at ~330hp @ 6.5psi. That is with a CTSC though. Perhaps I should investigate into my running lean.
