Melted motor mounts
So, I have been turbo'd for about 3000 miles with Innovative 60A mounts. Noticed my down pipe rubbing, so I checked it out tonight. Lo and behold, my passenger side mount has dropped down because the durometer is melted and stretched. I am using a PFab top mount ELT mani, so figured it would be ok. My questions are:
1. What mounts are you guys using?
2. Any way to keep the 60A's from warping?
3. Are the higher durometer Innovative bushings any better at withstanding heat?
4. Do the stockers withstand the heat?
5. Anybody using the Inline Pro motor mounts?
Any comments appreciated.
Im using stock myself with no issues so far , but with the downpipe going so close in that area and the hotside being right there its just borrowed time.
Im in to see if anyone is using the inlinepro stuff yet. I may switch over. The benefits are sexy on them.
To press the bushings in I used a long bolt & nut and a couple of very large diameter washers to squeze it together.
Personally I would recomend the factory mounts, they held up better than the Innovate on my car but, with a hardest bushing they will take more abuse than the factory at the expence of vibration through the car.
