Misfire...need help
hey i had the same problem you had. was battling this problem for almost 6 months. i also have an 06. i'm using flashpro. had the same misfire codes and couldn't figure out why. was using RC 1000 injectors and than switched to Deatchwerks 1300. ran good for one month and then the same misfire code popped up again. sent out the Deatchwerk injector out to get cleaned and balance. came back all good. bought some ID 1000 and it's all good now. somehow the ID 1000 has a different flow pattern and it cured all my misfire problems. hope this helps!!
