Misfire under Boost / Load
Old Sep 4, 2010 | 01:59 AM
lookinco's Avatar
We are suspecting it has something to do with the gas.
1. It started to happen RIGHT after I filled up a new tank. Before filling up, car drove absolutely fine.
2. The misfire was really really bad that I could not even rev past 5k rpm. Once I filled up with new gas again, right away I was able to rev past 5k but there is still hesitation and misfire.
I just filled up a new tank and with a bottle of fuel system cleaner. If it doesn't help I will try to inspect and change the fuel filter, and maybe drain the gas tank completely and put in new gas.
Old Sep 4, 2010 | 08:15 PM
RedLineS2k10's Avatar
I would check your injectors, it sounds like something is inside of them and is preventing proper flow, possible sticking closed sometimes or wide open....Check your fuel filter, fuel pump, and the little sock generally found on the pump and clean everything...You wouldnt believe the shit i found when i cleaned eveything. proper fuel delivery seems to be the problem
Old Sep 5, 2010 | 10:37 AM
ChefJ's Avatar
we don't have an easily accessible fuel filter on this car.
Old Sep 6, 2010 | 02:13 AM
lookinco's Avatar
Here is a datalog of a few runs:
http://www.theblackmarkers.com/datalog.zip
Any help is greatly appreciated!
Old Sep 8, 2010 | 11:56 PM
lookinco's Avatar
Going to check to see if the exhaust is clogged. Hopefully that solves it.
Old Sep 9, 2010 | 01:09 PM
lookinco's Avatar
FIXED!!
CLOGGED CAT
My berk hi flow cat disintegrated.
Old Sep 9, 2010 | 01:15 PM
ChefJ's Avatar
so it was just choking up? interesting.
ChefJ's Avatar
cat+fi=bad
Old Sep 9, 2010 | 01:17 PM
lookinco's Avatar
Yes but po po + tow trunk + impound is even worse.
But there is a 70mm testpipe in there now..... back to shooting fireballs
Old Sep 10, 2010 | 09:10 AM
EK9MAX's Avatar
I had misfire problems right after hard shifting.
and set of bkr8eix left at factory gap solved that.
And I'm running 18+ psi
