Misfiring?
Well, it's either spark or fuel. Definitely check plugs, cables, etc. Coil pack is definitely a possibility. Pulling the plug wires one at a time isn't a bad idea either. You definitely want to diagnose the problem before you start throwing parts at it.
I plan on changing the plugs (need it anyway)
Pulling coil pack wire to see if any are bad
And PnP injector wire troubleshoot also
Be good to see what the plugs look like. Symptoms sound like spark blow out to me. What is the gap set for? Sometimes you could be at the threshold of spark blow out, but won’t manifest itself until a condition changes, such as warmer ambient temps for example causing a bit richer a/f. Plug wear can cause this as well. Several things can.
I don't know what the gap is set at but I have a feeling that's the cause.
UPDATE: checked PnP injector wiring. They're al good. Whenever I pull one it turns into a boxer engine same with all four. Next going to check the coils then spark plug replace.
It's not happening at low rpm anymore now. Is just happening under boost.
Any more opinions?
Any more opinions?
I'd ditch the pnp cables regardless and my money is on plugs and gap. Or the wiring is intermittently faulty. Those things are crap spend the time and change them.
Any more opinions?
Any more opinions?
Any more opinions?
Any more opinions?
Originally Posted by s2000Junky' timestamp='1434565062' post='23651483
[quote name='RZA' timestamp='1434499906' post='23650638']
Any more opinions?
Any more opinions?
[/quote]
Good, keep us posted
Originally Posted by RZA' timestamp='1434567450' post='23651528
[quote name='s2000Junky' timestamp='1434565062' post='23651483']
Any more opinions?
Any more opinions?
[/quote]
[/quote]
Update:
So I changed the plugs tonight. All gapper to .20. And is still breaking up under acceleration.
I've checked the PnP injector cables. Everyone I pull affects the idle so those are good. And it's not the plugs.
What else could it be? Coil packs maybe? Any other suggestions?
What's happening: breaking up under acceleration, seeming rough idle from the exhaust but the motor sounds okay? Just like pops softly from the exhaust. Replaced spark plugs and checked injextor PnP cables. I need help lol
