Misfiring Problems
Old May 10, 2011 | 01:12 PM
batikan's Avatar
changed it lots of times...
Old May 10, 2011 | 03:48 PM
ChickenParm's Avatar
wiring on the injectors??maybe you disturbed one of the wires...can you pinpoint the cylinder? fuel pump not keeping up? i would guess a fuel problem try a new pump
Old May 10, 2011 | 04:50 PM
vduber's Avatar
It sounds like a spark issue but do a fuel pressure test for shaats and gags if you have a gauge set to see if shes putting out
Old May 10, 2011 | 05:23 PM
donaldmejr's Avatar
If he has a A/F Gauge then shouldn't the gauge show if the pump wasn't keeping up? Just wondering what is your Battery Voltage at WOT and redline?
Old May 10, 2011 | 06:09 PM
spectacle's Avatar
Do your MAP readings look right in the EMS? Have you data logged the problem? It should show up in the logs and give more insight
Old May 10, 2011 | 10:36 PM
batikan's Avatar
We have installed a brand new fuel pump when we swapped to Turbo. We will double check the wiring on the injectors too but I doubt it is a fuel related issue...
Fuel Pressure is fine. We will check the voltage or try a brand new battery...
We did but I will take a log again and see if we were missing something...
Old May 11, 2011 | 05:17 PM
any luck?
Old May 11, 2011 | 06:15 PM
Blucky87's Avatar
any chance you could post up a view of your log where it is happening or send it to me through email? blucky87@gmail.com I would like to see it
Old May 21, 2011 | 01:38 PM
batikan's Avatar
here is the latest update
we installed brand new spark plugs. we gapped them to 0.028, 0.024 and 0.020 and it did the same problem everytime. the car accelerates but keeps misfiring randomly between 7K to 9K
we installed brand new coils
we installed a brand new battery
we installed a new aem ems
we installed brand new injectors and did complete rewiring on the injectors
we installed brand new crank sensor
we installed brand new cam sensor
but nothing solved the problem
I tried to take a log but somehow we couldn't. after we start the log, let's say we are at 4K rpm, we start to accelerate but it stops at 6600=6700 rpm everytime and freezes there. it won't log past that rpm
Can this problem be from
a) an electrical issue and we need to get a brand new wiring harness?
b) can the alternator be working improperly?
Old May 22, 2011 | 07:31 AM
jonbar87's Avatar
Do you have good grounds? If you don't have good grounds it doesn't matter if you replaced everything, a weak ground can cause a lot of problems.
