miss fire problems
Old May 1, 2011 | 10:51 PM
neoleooo's Avatar
Default miss fire problems
I have a turbo charged 06 s2ki. it makes 430whp at 12.5lbs boost. im using a hondata flashpro with 1000 ID injectors. it has NGK iridium spark plugs(BKR7EIX). has the new aeromotive in tank fuel pump which is 350lph. also change to a return fuel system. got it tuned from sean at church automotive. car ran fine for about a month. it now sputters or hesitate at high rpm when i punch it and the check engine light flashes around 6 or 7 times. im guessing this is a missfire code. anybody knows what is causing this. i tried gapping the plugs already and still same problem. please help. thank you!
Old May 1, 2011 | 11:20 PM
DFWs2k's Avatar
first off, pretty sure you should be using plugs with the 8 heat range. how did they look when you pulled them out?
secondly, go to autozone and pull the codes
Old May 2, 2011 | 05:38 AM
dales2000's Avatar
i know this my sound a lil out there but did you check the oil level? Similar situation happened to a friend and the cause was lack of oil.
Old May 2, 2011 | 10:06 AM
urBan_dK's Avatar
Change to heat range 8 and gap to .032
Old May 2, 2011 | 10:23 AM
neoleooo's Avatar
plugs look fine when i pulled them. check the code and it was misfire. i will try 8 heat range. hope it helps. thanks!!
Old May 2, 2011 | 10:24 AM
neoleooo's Avatar
i will try that. thanks!!
Old May 2, 2011 | 12:12 PM
skool u's Avatar
I was having a few problems with hesitation and sound like misfiring. I ended up swapping out my coil packs and it seems like it helped. I haven't experienced the same problem yet (knock on wood).
Old May 2, 2011 | 11:33 PM
Haid628's Avatar
change the plugs to 2668 and gap them to .o25 im running 10lbs and its running fine
Old May 2, 2011 | 11:39 PM
daicacharco's Avatar
Are you running PNP connectors on your fuel injectors? I had the same problem and messed around with the wires a bit and the misfiring ended. Running the 2668 as well.
Old May 3, 2011 | 01:52 AM
neoleooo's Avatar
yes i have the PNP connectors. what did you do with the wires to fix the problem. what are 2668?
