Which model year is best to supercharge?
Old Apr 24, 2005 | 06:02 AM
Bikecrasher's Avatar
Default Which model year is best to supercharge?
If you were to put a supercharger on an S2000, which would:
1. Yield the best overall results throughout the powerband over stock?
AND
2. Most importantly (to me at least) make the car more exciting to drive.
I ask this because I know that the 04-05's have a 8000 RPM limit and a little more
tourque down low verses the higher reving 00-03's.
I know that I either want to buy a low milage mint 03 or a new 05 and eventually
supercharge it, so that is why I am asking this question.
Thanks,
Randy
Old Apr 24, 2005 | 10:52 AM
Sideways's Avatar
They are different.
The '04-'05 has more torque that will be magnified somewhat but the torque will peak at a lower rpm than the '00-'03. This results in a shorter powerband. With that said, either one will give you a thrilling ride if you push the envelope a little.
Old Apr 24, 2005 | 02:10 PM
CrazyCracker82's Avatar
all i know is....6-9000 is f in nuts with my foot all the way down in my 00. good luck
Old Apr 24, 2005 | 05:05 PM
S2000RAT's Avatar
I like the 9K red line.
Old Apr 25, 2005 | 05:26 PM
EriS2k's Avatar
Gottla Love the 9k Rpms with Boost!
Old May 17, 2005 | 02:27 PM
Silver S2k4's Avatar
get the 03. I have an 04 and would much rather have 9k again like in my old 00.
Old May 17, 2005 | 05:18 PM
s2kgeek9's Avatar
Taking into consideration that all Honda did to create a 2.2L was to increase the stroke, I would rather boost an 00-03 personally.
Keeping in mind the higher pistons speeds with the longer stroke, thus why the redline was dropped to 8K vs 9K, I just think it would be ever so slightly safer on a 2.0 vs 2.2.
Either way, it's going to be one hell of a ride, and if tuned properly, neither should have any problems.
BTW... not sure if I would do it boosted, but I know of a few people running 04 motors off of 02 ECU's, and running them to 9K with no issues. They are quite fast too, probably running the motor a little leaner than if it had an 04 ECU connected. Thus gaining a little more out of it.
Old May 17, 2005 | 06:15 PM
nsxinsac's Avatar
For the price difference, I would go with the 03. You get the 9k redline, glass rear window and its cheaper so you can put that savings into your 03 I don;t know if there is any major difference but I'm sure either way you go you will be happy. 9k redline is a trip but both chooses have there perks.
Old May 17, 2005 | 06:24 PM
nibble's Avatar
00~01 has issues with "other" parts. '03, they changed the ecu.
Old May 17, 2005 | 07:29 PM
Honda_mann's Avatar
