modifing intake manifold
Old Nov 28, 2011 | 08:05 PM
donaldmejr's Avatar
Default modifing intake manifold
Guys since my car is down for the winter I would like to clean up my intake manifold by getting it powder coated. I was wondering if you could mill off some of the casting marks and unused bolt holes (what held the fuel rail cover)? I would also like to mill off the not need egr port and plug the hole as the 06+ models didn't have that. Is this do able? Can people post pics of there intake manifolds.
Old Nov 28, 2011 | 08:16 PM
H4RD ON's Avatar
I actually started making my own manifold using the the stock runners....I got a little trigger happy when it came to the EGR. Since i've got AEM and will no longer need it i completely grinded that entire part away...i'll post a pic tomorrow.
Old Nov 28, 2011 | 08:24 PM
donaldmejr's Avatar
I would like to do the same as I feel it looks tacky
Old Nov 28, 2011 | 09:19 PM
Leviisbigred's Avatar
im in for pics
Old Nov 29, 2011 | 06:09 AM
Sideways's Avatar
My current manifold is over 3-1/2 lbs lighter from removing material.
https://www.s2ki.com/s2000/gallery/i...1-dsc01316jpg/
I removed in total the smog pump flange and some bosses.
There is a large amount of aluminum that can be removed from that area.
https://www.s2ki.com/s2000/gallery/i...2-dsc01315jpg/
The braces are modified and removed.
The coolant flow parts were removed from the front of the manifold.
I only burp the coolant at the firewall. Works great.
https://www.s2ki.com/s2000/gallery/i...7-dsc00056jpg/
In this bottom view, all of the casting excess was removed from the runners.
Now it it easy to remove and replace the manifold. No blood loss from cuts.
Fingers fit between the runners to install the bolts, no long extensions necessary.
Old Nov 29, 2011 | 08:29 AM
donaldmejr's Avatar
sideways...any pics?
Also I know you ported your blower and AC any pics of that I would like to do the same just not sure by how much I can do.
Old Nov 29, 2011 | 06:28 PM
donaldmejr's Avatar
well i said F it and started cutting and grinding away at the intake manifold
Old Nov 29, 2011 | 06:59 PM
ScorpioMk's Avatar
I started cleaning mine up last week, friend used a mill to knock off the stuff on the top, and I welded the holes shut. After cleaning it back off I welded a couple little holes back up and hes gonna knock it down final.
One more pass after this, then gonna cut off the egr stuff and weld a few other holes shut.
Old Nov 29, 2011 | 07:42 PM
donaldmejr's Avatar
Lucky you and your mill...I want one so bad!!
Old Nov 30, 2011 | 01:52 AM
cant see any pics
s20004lifehomes
Jun 30, 2015 03:22 PM
LINESUPER
May 4, 2011 12:32 PM
roi
Jul 15, 2009 10:33 PM
menkio
Mar 25, 2008 01:41 PM
sophis
Apr 18, 2005 09:25 PM
