More gauges or new dash/cluster
Old Oct 24, 2015 | 03:24 PM
cheddaboy's Avatar
Default More gauges or new dash/cluster
So I currently have two gauges on the steering column(boost and afr). I plan on adding a couple more for water and oil temp as well as oil pressure. I was thinking of using a couple PLX multi gauges, but realized it may be more efficient and cost effective to just run a full race dash. I'm not sure of the cost to run the additional sensors for the features I'm looking for, but I assume I would need multiple sensors on top of the price of the cluster.
1. Cost wise, what would be more?
2. Does anyone else here have a dash they're using? And how user friendly is it?
Old Oct 24, 2015 | 04:12 PM
mr-pitts's Avatar
I got a Race technology dash I could let you have,I want £500 gbp for it but it's got the facility for all you need plus.
Old Oct 25, 2015 | 02:19 AM
mr-pitts's Avatar
[attachment=86683::]
[attachment=86684::]
[attachment=86685::]
[attachment=86686::]
It's got a custom made bracket to fit into the S2000 dash,4 function buttons for switching modes/screens.You can get a dedicated patch lead to the Ecu plus independent feeds from various sources fo things like fuel pressure/ temp ect.....and all normal repeater lights like turn signals,high beam ect.
Attached Thumbnails More gauges or new dash/cluster-image-1791171794.png   More gauges or new dash/cluster-image-4083410833.png   More gauges or new dash/cluster-image-2631565788.png   More gauges or new dash/cluster-image-766353750.png
Old Oct 25, 2015 | 03:42 AM
cheddaboy's Avatar
I just want to weigh out the pros and cons first. Why are you selling it?
Old Oct 25, 2015 | 12:09 PM
mr-pitts's Avatar
I've replaced it with the Motec m125 dash,more compatability with my Motec ecu and quaife gearbox.
Old Oct 26, 2015 | 01:54 PM
S2K-F8's Avatar
I'm running 2 PLX Multi Gauges. 1 for boost, the other for A/F (also has oil temp and oil pressure sensors hooked in). I'm running Kpro 4, so I monitor other things from my smartphone (AIT's, water temp, ethanol %, etc)
I don't really like the looks of A-pillar gauges, so here was my solution
Scott-
Old Oct 26, 2015 | 02:35 PM
cheddaboy's Avatar
Scott-
How do you control your heat vents?
Old Oct 26, 2015 | 02:59 PM
S2K-F8's Avatar
Since I added a CR center console, I ended up with an extra rear defrost button. I moved/modified the hazard button to the center (CR hardtop defrost), then moved/modified the vent control to sit where the hazard button used to be
Old Oct 26, 2015 | 03:17 PM
Redline S2K's Avatar
I use the Enough Logic bluetooth adapter that sends information to an iOS device. Only works with AEM though.
Old Oct 26, 2015 | 05:09 PM
liquidgsr's Avatar
I have the Enough logic adapter as well and I have my AEM BOOST and AEM AFR gauges in my fear view mirror.
