Are My Compression Numbes Ok?
Old Jan 19, 2010 | 07:22 PM
Bennett124's Avatar
Banned
Default Are My Compression Numbes Ok?
Alright so my s2000 has been running just fine I have had no problems at all with it. The motor has about 10k miles of being turbo charged on the fresh build with CP 9:1 compression pistions in it and I wanted to do a compression check on it just for piece of mind. I just finished and this is what I came up with.
What do you guys think about the numbers?
#1-145
#2-150
#3-145
#4-140
And yes I did drive the car around until it got up to operating temperature.
Old Jan 19, 2010 | 07:55 PM
Spoolin's Avatar
The numbers are all fairly close together which is good but they seem too low for 9:1 CR. Shouldnt they be closer to 180's?
Old Jan 19, 2010 | 09:31 PM
siadam's Avatar
I'd think, but I bet he didn't hold the throttle to the floor, I've seen taht cause low numbers.
It's hard for the motor to pull any air through a closed TB.
Old Jan 19, 2010 | 10:16 PM
Spoolin's Avatar
Oh yeah, you are correct there. I hadnt thought of that but I bet youre right. Good call. SO, if thats the case, then he should be good to go as all the numbers are fairly consistant.
Old Jan 19, 2010 | 11:05 PM
m R g S r's Avatar
all testers read differently. be concerned with the % difference between the highest and lowest. if they are really all that low, then maybe something is wrong with the HG sealing, but you would have coolant/overheating issues if that were the case.
Old Jan 19, 2010 | 11:46 PM
Bennett124's Avatar
Banned
Yes I did hold the throttle open all the way when I was doing the test. I will try to get my hands on another compression gauge and see if the numbers change at all.
Is the somewhat low numbers something I should worry about or not so much?
Old Jan 20, 2010 | 06:25 AM
spectacle's Avatar
If it drives fine I wouldn't worry too much about it
Old Jan 20, 2010 | 07:08 AM
dsddcd's Avatar
If you want a real idea of what is going on you need to do a leak down test. Here is one I made that works quite well.
Old Jan 20, 2010 | 12:46 PM
civicej8's Avatar
what kind of headgasket do you have? im sorry i might of missed that.
Old Jan 20, 2010 | 01:13 PM
Deception's Avatar
stock HG w/ 9:1 pistons
