my comptech diff has just failed
I use 75/140. Its proven to me to be the best weight for stock diff after switching over for many miles now. Makes sense, the cold weight is still standard for proper flow rate/lubrication and the hot weight is thicker to help cushion and protect the diff under added stresses. I DD and road course the car with this fluid, so its proven for me.
The end caps usually wont break, they flex. That's the issue with stock equipped diffs, especially the ap1. You still may not have had enough reinforcement on the end caps with the comptech diff (considering you still damaged the ring and pinion gear) thats exactly whats happens when the end cap assy flexes and the gears go out of alignment. The gears themselves secondarily could still be a weak point.
Comptech does nothing with the crush collar. From what I hear, puddy builds a custom sleeve to replace the crush collar, making the above pretty much never happen.
Hi Benton,
my puffy mod stage 3 with 3.9 gears just shipped. Looks good so far.
This pic shows the assembly...PuddyMod solid steel sleeve is on the pinion Note the shot peen finished gears.
This pic shows balancing the carrier and the ring gear, balance is just at a thousands true round.
This pic shows the PuddyMod solid steel sleeve being set
This pic shows the turning torque on the pinion after the PuddyMod solid steel sleeve is custom fitted, it is set at 12 inch pounds.
This pic shows the backlash set at 2.4 to 3.0 thousands, it also shows the perfect gear to gear pattern.
This pic shows the finished rear build. Note the information on the LSD also note the shot peen finished gears.
THE REAR IS SHIPPED DRY WITH NO OIL INSIDE PLEASE ADD OIL BEFORE USE
Break in,
This rear will hold power very well but is not bulletproof! Be sure to rev match your shifts! When you launch the car preload the drive train, be smooth, and get some tire spin.
Use a good quality GL-5 Hypoid 75/140 gear oil in the rear. Use this oil in the rear for 500 miles then drain.
Use Amsoil, Mobil1, Valvoline, or Motul 75/140 gear oil every 12K miles.
When you receive the rear, fill it with oil Be sure not to over fill the rear, fill the rear until the oil starts to come back out of the fill hole. Replace the fill bolt once the oil slows to a light trickle
More Break in:
Drive the car like a civilized human for 300 miles, No launching, power shifts, or hard down shifts. After 300 miles the rear is fully broke in and “normal” driving can begin.
Thanks
Ben
Break in,
More Break in:
Thanks
Ben
So I been drive the car with the new puddy mod stage 3 diff and 3.9 final drive for about a week now and I love it. The diff is dead quiet and the 3.9 years do make each gear noticabable longer. Cruzing rpm on the freeway is about 400-500rpm lower. When my speedo reads 80mph I'm actually going about 86mph. This will definitely help with my traction problems as 1 to 3rd gear is much more usable now. As before 1st and 2nd gear were only burn out gears and were useless. 2nd gear is now somewhat usable and of course 1st gear is still useless. Over all I'm happy so far with this new diff.
Thanks
Wasn't much of a difference, but I'm still happy having a beefed up diff.
http://www.turnzero.com/technical_re...ear_calculator
Thanks
