My gauge set-up
As requested, here are a couple pictures of my gauge set-up.
Gauges from left to right:
(navigation unit) EGT, Oil Pressure, Oil Temp, Water Temp
Top gauge is boost, middle is fuel pressure, and right is A/F. Yes I know the gauges don't match but they came with an item I purchased in the past so I figured I might as well use them. Also notice the radar detector alert display mounted on top of the steering wheel, just in case I can't hear it beeping I surely will see the flashing red light below my MPH
And my Boost controller (also a boost gauge that reads in PSI, my other one is only KPa)
I like to know everything that is going on with my engine. I wonder what other gauges I can cram in there
Originally Posted by TelosHedge,Apr 19 2008, 07:17 PM
check your oil pressure - i think you have a problem
you could still have voltage and and IAT if you wanna go nuts!
i love my iway250c
only beef with it is the motha effing start up time
i want a rear view mirror with temp and compass. Spec_Ops, theres how you could get OA Temp. nice set up by the way. did you do the dash gauges or have them done? i also have the radar detector thing mounted right on top of the plastic steering wheel piece. its the piece that had the remote V1 display molded in fiberglass maybe 2 months ago in the fs area.
Originally Posted by SDUECE,Apr 19 2008, 09:08 PM
Wow, S2000 fighter pilot. I really need to get me some gauges. What other gauges do you need? Voltage or Trans Temp?
