my new catch can!
Old Apr 13, 2011 | 06:48 PM
jared50438's Avatar
Default my new catch can!
there it is! i just wanted to show it off and see what you guys thought of her!
put a lot of time into cleaning it up and making it how i wanted!
front of my car!
put some work vsxx's 18x8+38 18x9+38 ,235 40 18, 255 35 18
just installed an ap2 trans with less than 30K on it also my 2nd gear went out last weekend.. twin disk still looks like new!
hope you like!
Old Apr 13, 2011 | 06:53 PM
gnehc1's Avatar
nice! how much whp are you making?
Old Apr 14, 2011 | 03:41 AM
hondaguys2k's Avatar
nice setup! is it stage 1 or 2 kit? if a stage 1 is the fuel rail necessary? i just bought the kit from someone and have my stock fuel rail. just curious.
Old Apr 14, 2011 | 04:22 AM
dc2-2-ap1's Avatar
that is the stage 1 kit (stage 1 has a log manifold / stage 2 has a tubular manifold- turbo is in front of motor) and you will be fine with the stock fuel rail unless you plan on running over 15psi
Old Apr 14, 2011 | 05:24 AM
DFWs2k's Avatar
What makes you think a fuel rail is needed over a certain psi?
Old Apr 14, 2011 | 08:54 AM
camuman's Avatar
i love the work wheels!
Old Apr 14, 2011 | 11:49 AM
jared50438's Avatar
the stock rail is fine for a lot im sure of it, b series guys have 600+ on stock rails.
i bought the car in WV this fall, all the work was done by inline pro, it made 500 or so at around 20 on 93oct. i plan to get it retuned with a different map sensor and some other things like that.
it also has a gt35r ball bearing turbo on it.
i keep it at wastegate pressure which is about 10-12 psi.
thanks for compliments! yea the works need rear tires! and i cant get the center caps on the rear because of the ip rear end...
also this winter i bought the heater line bracket and AC lines from the sponsors and a hondata intake manifold gasket.
next i want to get a new short block before this one goes and then get another pump with bigger injectors and e85 (im in iowa) and go for 650 or so.
Old Apr 15, 2011 | 07:38 PM
S2k.berto's Avatar
Old Apr 15, 2011 | 08:52 PM
bois2k's Avatar
[/quote]
i have head the hondata intake manifold gasket is not good for boosted aplications someone correct me if im wrong plz.. love the custom catchcan and youre ride =D
Old Apr 17, 2011 | 05:15 AM
ap1tuner's Avatar
I'm liking tha catch can. Very nice and a simple design that does the job. Jw, how much did it cost to make?
SWIFT2000
Apr 15, 2010 04:25 AM
Thanhstar
Oct 13, 2009 09:58 PM
Polemicist
Car Talk - Non S2000
Aug 9, 2008 11:15 AM
bigmos2k
Oct 1, 2007 02:15 PM
tloc
Sep 10, 2005 10:57 PM
