SMIC = side mount intercooler.
i want to steer away from a front mount because of piping lengths/routing and of course because i'm only pushing a measly 6 psi. in terms of lag there really wont be a change, just a drop in pressure to the IM because of all the piping - hence why i'd like to do a short route smaller intercooler mounted a little closer to the IM. i have to think about different ideas to make it work still. i think those v mount setups are pretty bad ass but i dont have the experience with all that fabrication - plus i thnk the charger will get in the way. liquid-->air might be cool but due to the price i might veer away from that. maybe i can get a custom PWR setup for around the same and at least be original ;) keep the ideas flowing! |
Side mount? Where?
And where does it get it's airflow from? There have been a few PWR setups already. |
thinking about keeping it close to the IM and running some ducting to it. not sure yet still brainstorming.
289 on a dyno dynamics are pretty respectable numbers. Unless your dyno operator switched it so it reads like a dynojet. I remember when I dyno'd my evo we could switch how it read dd or dj 209dd 271dj. I think I remember someone posting up a greddy dyno on a dd making like 260ish.
nah i don't think he cared enough to do any switching around - he seemed to be very bored at work. :)
This is an F20C with CTSC and aftercooler as a stock install.
Only addition is Krank Vents and Mugen Exhaust. My numbers are not that different to yours. IMHO yours looks a bit lean (or mine is rich ;) ) https://www.s2ki.com/forums/index.ph...age&img=419674 |
Mine is also an F20C with CTSC and aftercooler as a stock install :)
https://cimg8.ibsrv.net/gimg/www.s2k...a3ce600c76.jpg And yep i think yours looks lean towards the end of the run! |
Mikey your a/f is perfect what did you tune with? The op seems pretty lean to me.
my car is reported as a bit lean but i was told i have to take into consideration that the wideband probe was placed after the cat. given that circumstance am i still too lean?
i am noticing that you guys made ~30 more ft/lb of torque than me across the spectrum - am i safe to assume this is because of the aftercooler? i am looking into cooling options for my next immedate mod. |
