NEED HELP ASAP!
Old Dec 12, 2005 | 04:43 AM
lexar13's Avatar
Default NEED HELP ASAP!
WHILE LOOSENING MY TENSIONER PULLEY ON THE VORTECH SC THE BOLT GOT SCREWED OFF. NOW WHEN I WENT TO TIGHTEN THE PULLY THE SCREWES JUST KEEP GOING DOWN THE THREADS AND I CANT TIGHTEN THE PULLEY TO FININSH THE PROJECT....WHAT DO I NEED TO DO???????????
Old Dec 12, 2005 | 05:39 AM
Sideways's Avatar
Call Vortech and get a replacement. Remember the Vortech has two points to loosen before adjusting and two points to tighten.
Old Dec 12, 2005 | 12:48 PM
lexar13's Avatar
IS THEIR ANY OTHER WAY ....LIKE USING SOME LOCK TIGHT???
Old Dec 12, 2005 | 01:31 PM
honda9krpm's Avatar
remove them off completely
replace them with different bolt and nut
rethread the hole if necessary
this will probably be quicker than waiting for parts from vortech
Old Dec 12, 2005 | 01:46 PM
MB's Avatar
MB
Member
Which bit do you mean exactly?
The Nylok nut at the bottom, the adjuster nut, or the nut holding the pulley on??
MB
Old Dec 12, 2005 | 02:17 PM
lexar13's Avatar
I THINK THE ADJUSTOR NUT...IT IS THE 14MM NUT YOU PUT THE SOCKET ON AND TURN
Old Dec 12, 2005 | 02:52 PM
honda9krpm's Avatar
what ever bit that stop you from tightening the bolt and nut
Old Dec 12, 2005 | 03:12 PM
lexar13's Avatar
WHAT??
Old Dec 12, 2005 | 03:30 PM
Slows2k's Avatar
Please turn the caps lock off. It makes you look like you are screaming.
The vortech belt tensioners that I have worked on have a 19mm locknut on the tensioner , and a 10mm headed bolt on the tensioner jackscrew. I'm not sure what 14mm bolt you are turning.
have you seen this thread in the FAQ: https://www.s2ki.com/forums/index.php?showtopic=115118
Old Dec 12, 2005 | 03:31 PM
r_duff's Avatar
making my eyes bleed here...
