need help choosing high flow cat
Old Jun 16, 2009 | 07:12 AM
roy365's Avatar
Heres random tech's site that also carries universal's for you to custom fit.
http://www.randomtechnology.com/products.html
down at bottom is universal apps.
Old Jun 16, 2009 | 07:33 AM
camuman's Avatar
thanks for the link, i will check it out.
Old Jun 16, 2009 | 07:36 AM
roy365's Avatar
I think you really want asura's.......so i bet you will wait for it to become available. LMAO.
Anyway's, you do have options so its all good.
Old Jun 16, 2009 | 11:40 AM
combats2000's Avatar
I have a vibrant racing resonator welded on my 70mm test pipe. nite n day!
http://vibrantperformance.com/catalog/prod...&products_id=47
Old Jun 16, 2009 | 12:52 PM
dsddcd's Avatar
[QUOTE=camuman,Jun 14 2009, 03:27 PM] i am running the asura 3" dual with a 2.5" resonated test pipe right now.
Old Jun 16, 2009 | 04:36 PM
Harpoon's Avatar
To the OP - you are supercharged, correct? If so, you might want to re-think the whole highflow cat thing. Comptech used to sell highflow cats and were adamant that supercharged cars should either run the OEM cat or a testpipe. I don't remember why.
Old Jun 16, 2009 | 06:40 PM
Revenge's Avatar
I would think a SC would have less of a need for a TP then say a turbo. Go with what will makes you happy, I would lean to Asura 3" HFC. Best flow, least amount of smell and a bit more easy on the ears.
Old Jun 16, 2009 | 06:59 PM
jwa4378's Avatar
Camuman - What exhaust are you running? I am turbo, running a T1r-EM single 70mm, and its DAMN quiet (MUCH quieter than when I was NA with a test pipe). Resonators / exhaust resonance are major factors, IMO, to an overall "civilized" exhaust tone.
The change in the exhaust from my RS*R 70mm single to the T1r was HUGE. Both had test pipes. The only variable was the cat-back portion.
John
Old Jun 17, 2009 | 08:29 AM
roy365's Avatar
My setup has less drone and seems quieter w/test pipe over my HFC. Was a definite "tone change" there as well. I like the HFC for smell and flow, but the sound w/test pipe is much more enjoyable in the drone problem areas now.
Old Jun 17, 2009 | 08:41 AM
btstone84's Avatar
strsight through exhaust, **** a cat
redsands
Jun 14, 2011 07:51 PM
ConeBarron
Apr 8, 2009 01:53 PM
rotary head
May 25, 2008 10:42 AM
REVZ TO9
May 1, 2006 09:50 AM
2_and
May 2, 2004 10:00 PM
