Need help! Ems connection to laptop
Old Feb 17, 2010 | 07:58 PM
TRBOKEV's Avatar
Thumbs down Need help! Ems connection to laptop
I need help!
I've been using my laptop to monitor ALL of my engine parameters, but when I was getting pulled over by the cops I yanked the plug out and closed the laptop and now I can't reconnect.
I've tried everything from reloading the ems software etc but no luck.
Help please!!!!!
Old Feb 17, 2010 | 08:14 PM
MaseEngineering's Avatar
Banned
lol. check the connection at the EMS.
Old Feb 17, 2010 | 08:17 PM
TRBOKEV's Avatar
I did already, that was the first thing I tried over an hour ago... It was loose but I tightened it and it still doesn't connect.
Old Feb 17, 2010 | 08:19 PM
X-RAYED's Avatar
Could be a grounding issue.
Old Feb 17, 2010 | 08:23 PM
Banned
err. im leaving work now...will call u on the way home.
Old Feb 17, 2010 | 08:40 PM
Spoolin's Avatar
Ive had some problems getting my laptop to connect to the AEM EMS at times, just keep trying. Also, make sure the com port youre connected to is on and working properly on the laptop. I'm sure its just something simple. You can also switch between USB ports to see which one is on and working, same as checking the com port connection, just manually.
Old Feb 17, 2010 | 08:44 PM
MaseEng Nick's Avatar
when you say you yanked the plug out, do you mean from the ecu or from the computer?
Old Feb 17, 2010 | 08:54 PM
TRBOKEV's Avatar
Figured it out, thanks Mase!
scottieboy561's Avatar
why didnt you just close the laptop and not yank anything out?
Old Feb 17, 2010 | 09:00 PM
Spoolin's Avatar
Well....What was it? Spill it man!
