Need info on comptech
Old Sep 9, 2006 | 03:43 PM
imdarkrider's Avatar
Default Need info on comptech
Sup guys... I wanna get a Comptech supercharger with aftercooler... but I want to run around 9psi - yea its high but oh well... What should I run as far as management , should I get a apex-i VAFC2 , or stay with what they give me? Also what pulley will give me what i'm trying to get and who makes it. Thanks for all the help
-FI noob
Old Sep 9, 2006 | 03:54 PM
afwfjustin's Avatar
The stock injectors are only good up to around 7 pounds of boost. After that, you run too lean and you'll blow your motor. You can get bigger injectors, but you need a standalone to control them. Going from stock boost to 7 pounds is cheap, but goign from 7 to 8 or 9 costs you an extra 2 thousand dollars
Old Sep 9, 2006 | 04:18 PM
abv's Avatar
abv
Dear noob....love that term...
Im running rc650 injectors with a comptech system
aem ems
also I have a 3.5" pulley = (for me stock motor) 11 psi
aslo have a shorter belt (dont have the part number its a goodyear a search will find it)
I would reccomend ti retainers (supretech or rev)
and change the valve springs search youll find info
and do the oil squirter upgrade maybe a clutch (competition or act)
kane.s2k can help you out with any parts you need.
feel free to pm me with questions if you have them
Old Sep 9, 2006 | 04:37 PM
Dsgs2k3's Avatar
you need 550cc injectors, a tuning device like emanage or EMS, 3.5 inch pulley-you can get tech2 or ASP and time on the Dyno
Old Sep 9, 2006 | 08:49 PM
backman_66's Avatar
What's the smallest size pulley (WITH aftercooler) you can run on stock injectors and no tuning? like, what size pulley would yield 7psi?
Old Sep 10, 2006 | 02:13 AM
abv's Avatar
abv
call comptech get the ap2 pulley size or get one through them
adjust the fpr
get a belt...
Old Sep 10, 2006 | 06:38 AM
Dsgs2k3's Avatar
4.0 inch pulley for 7psi, that will max out the injectors
Old Sep 10, 2006 | 01:46 PM
Nhan's Avatar
3.5 for 9psi right? or is 3.5=9-11psi?
Old Sep 10, 2006 | 02:17 PM
abv's Avatar
abv
depends on rpm 9200=11pounds 9000=around 10+pounds
this is on an ap1...
there are a lot of variables involved here as far as what size pulley will give you what amount of boost too much to go into here but search around you'll find a bunch of stuff about it..
Old Sep 10, 2006 | 02:57 PM
Dsgs2k3's Avatar
