Need Input, Nitrous Backfire
Old Jul 20, 2006 | 08:09 PM
benjy's Avatar
Default Need Input, Nitrous Backfire
Hey whats up, The other day during an installation of a wet zex kit on my s2k a not so small nitrous backfire occured. The people who installed it accedentally activated the system a few times, filling up the intake with nitrous and fuel. Long story short, i started it, big....big boom.
Damages: Bent the throttle body butterfly in 2 different directions. Blew off the CAI and put a decent size dent in it. Scorched some sound damping material on the hood. Now it idles rough when A/C is on. I smell antifreeze from my air vents and from under my hood. No knocking or pinging, doesn't seem to have any white smoke from the exaust.
so what else should i look for.... and what could other problems be??? thanks alot for the help `Ben
Old Jul 20, 2006 | 09:23 PM
NFRS2kSi's Avatar
swap a motor.
Old Jul 20, 2006 | 10:02 PM
Dark's Avatar
that strong of a backfire is not from fuel in the intake track....and nitrous wont just 'wade' around, it turns to gas and you would need a good amount of gas in there to make that much of a 'boom'.
If I were you I would double check their wiring. Are you using the ZEX box? if so I would highly recommend you buy some new solenoids (NX or dynotunenitrous.com).
I understand alot of people run a single nozzle wet kit but its not good for the motor at all; a direct port kit is MUCH safer.
Old Jul 21, 2006 | 02:07 PM
dereks2000's Avatar
check map sensor. with enough beating - the throttle plate could be used again. it will never idle the same until you have a new throttle body - good reason to go aftermarket (not that you'll make power). my motor went through almost the same thing. it ran strong as it did before the bottle...till i sold it - which was over a year and 30,xxx later. you'll be fine. also - take the valve cover off and look at the baffle in the top. when i had a solenoid stick open - it seperated the baffle from the valve cover - used a punch and hammered her back on. good as new. dont fret - if it sounds good and runs good - it'll be fine. oh - with the valve cover off - do a valve adjustment.
Old Jul 23, 2006 | 02:48 PM
geists2k's Avatar
Damn!
blazins2
Jul 29, 2013 06:48 PM
Wydget
Jul 9, 2012 01:10 PM
saikiran_paturi
Oct 29, 2008 02:18 PM
djpeak10
Aug 10, 2006 11:38 PM
SSS2k
Feb 24, 2004 11:26 AM
