Need shaft size for Vortech SC
Old Mar 25, 2009 | 09:32 AM
krazik's Avatar
Administrator
Default Need shaft size for Vortech SC
Anyone have it?
I'm trying to find out if the paxton 1200 has the same shaft size as the vortech. I think it does.
So I need to know what the diameter of the vortech shaft is.
https://www.s2ki.com/forums/index.ph...&f=11&t=682269
Need info asap.
Thanks
-Ry
Old Mar 25, 2009 | 09:50 AM
camuman's Avatar
that is awesome! but i dont have the info you need. bump for someone to help this brotha out.
Old Mar 25, 2009 | 03:41 PM
Slows2k's Avatar
Do you need inlet diameter or input shaft diameter?
Old Mar 25, 2009 | 03:45 PM
Slows2k's Avatar
http://www.vortechsuperchargers.com/product.php?p=6
Old Mar 25, 2009 | 05:24 PM
krazik's Avatar
Administrator
I need the shaft size for the pulley. I have found out that the paxon 1200 and the vortech have the same sized shaft and can use each other's pullies (Not sure if centerlines match up tho, we'll machine that to fit).
-Ry
Old Mar 26, 2009 | 10:44 AM
klimaxx805's Avatar
Yes, the NOVI 1200 has the same shaft size as the Vortech Si, SCi, T, and YSi. Vortech owns paxton and they share the same R&D department. Vortech engineered the NOVI 1200, 1220, 1500, and 2200. The Vortech pulleys are interchangeable on the NOVI models listed. They will not work on the NOVI 1000, or 2000.
-Frank
boostinbort
Jul 17, 2016 08:36 PM
Kondor999
Jun 13, 2007 01:36 PM
615s2k
Aug 6, 2004 05:48 AM
evo s2000
Jul 23, 2002 09:03 AM
