New turbo kit is in!
Old Apr 6, 2007 | 09:43 PM
2QYK4U's Avatar
Default New turbo kit is in!
I used to have the inlinePRO turbo kit with the following items:
1. Precision GT3071R ball bearing turbo
2. inlinePRO Cast Iron T3/T4 turbo exhaust manifold
3. Turbosmart 38mm wastegate
4. inlinePRO billet blow-off valve
5. 2.5" mandrel-bent aluminum charge pipes (mirror polished)
6. inlinePRO 600hp front mount intercooler
7. inlinePRO 3
Old Apr 6, 2007 | 09:54 PM
John_Z's Avatar
When are you hitting the dyno? Looks great btw
Old Apr 6, 2007 | 09:58 PM
wannabuy's Avatar
Looking good. Don't you just love that manifold?
-Chris
Old Apr 6, 2007 | 10:04 PM
AGBLLET's Avatar
SWEEEEEEEEEEEEEET!
Old Apr 6, 2007 | 10:23 PM
milkbubble's Avatar
Clean!
Old Apr 6, 2007 | 10:29 PM
2QYK4U's Avatar
I was supposed to have the car re-tuned and dyno'd tomorrow morning, but I have a few issues that need to be resolved:
1. My car is trying to boost up to 18 psi or so (even though my boost controller wants to limit it to 10 psi). I am trying to verify the spring rate in the wastegate. More than likely it is a 1.2 bar or so. If that is the case I will need to have a smaller spring put in.
2. My BOV isn't going off and I am getting compressor surge. Very strange. The lines are hooked up correctly, but I believe there is a nut on the inlinePRO BOV which you can adjust.
Once these issues are resolved I will hit the dyno!
Old Apr 6, 2007 | 10:31 PM
2QYK4U's Avatar
-Chris
IMHO the Full-Race manifold is the best on the market. The welds are incredible, and the runners are just screaming for power!
Old Apr 6, 2007 | 10:33 PM
SPECIAL-OPS-S2K's Avatar
did you remove the ac or route the lines elsewhere
Old Apr 7, 2007 | 12:22 AM
2QYK4U's Avatar
A/C was gutted over a year ago.
Old Apr 7, 2007 | 12:25 AM
passmans2kny's Avatar
wow looks sick, did u remove the ac?
