Nitrous on an 06
Old Jun 1, 2009 | 12:01 PM
SixToeRen's Avatar
Default Nitrous on an 06
Does anyone know the wiring color for the TPS on an 06? It seems to be different then the earlier models. I tryed measuring the three wire with a multimeter but Im getting the same voltage weather im at 0% or 100% throttle.
The wire on the left gives me a constant 5V, middle wire shows 2.8V, and right wire shows 0V.
Does the engine have to be running for the voltage to change?
Old Jun 1, 2009 | 03:04 PM
SixToeRen's Avatar
anyone? noone has nitrous on thier 06+ DBW s2000?
Old Jun 1, 2009 | 04:16 PM
S2Kart's Avatar
This is not from an '06 but since they all use a voltage dividiing potentiometer it might be the same.
Old Jun 1, 2009 | 05:16 PM
Slows2k's Avatar
DBW cars don't use a 3 wire TPS sensor..
Old Jun 1, 2009 | 06:28 PM
SixToeRen's Avatar
Thanks. The voltage readings im getting arent making any sense. Its either a consistant 5volts or some wierd numbers that dont change when the gas pedal is pressed.
Old Jun 1, 2009 | 06:31 PM
SixToeRen's Avatar
Do you know which wire the TPS is? There are six wires coming out from the right of the throttle body. Im guess its for the DBW and TPS but none of them are giving me 0-5volts at 0 and 100 percent throttle.
Old Jun 1, 2009 | 06:52 PM
Slows2k's Avatar
I'll have to look at a ETM later... IIRC, the connection will be at the APP sensor and not the throttle body
Old Jun 1, 2009 | 06:54 PM
SixToeRen's Avatar
Sweet Thanks. I basically have everything hooked up execpt that wire.
Old Jun 1, 2009 | 08:42 PM
JuicedS2K's Avatar
I know mine is red/black, 04 though.
Old Jun 1, 2009 | 09:01 PM
SixToeRen's Avatar
yeah on the pre DBW the wires are on the left of the throttle body. On the 06+ theres nothing there and there are 6 wires coming fromt the right side of the throttle body. None of them seem to be the correct wire.
