Nitrous, Diff, DR's
Old Jul 24, 2008 | 05:41 AM
Tjs S2k's Avatar
Default Nitrous, Diff, DR's
I know that nitrous isnt exactly FI, but I think this forum you guys would know the most about higher HP S2ks at the track. Yes I am going spray, and yes I drag race the S. Just wondering what else I should reinforce. I have a comptech diff, soon to have a HTG Clutch/Flywheel, I wanted to run Drag Radials for when Im at the track. What is the weakest link in that combo?
Edit: The spray is only for the track, maybe 2-3 times a year. It will be a 75 wet shot spraying at 6k in first
Old Jul 24, 2008 | 06:24 AM
shawnAMT's Avatar
I dont think the comptech differential will stand the force of the drag radials but I could be wrong. Hopefully other people will chime in
Old Jul 24, 2008 | 06:42 AM
btstone84's Avatar
inline pro diff kit is the shit
Tjs S2k's Avatar
/\ Yes but I dont have that kind of money laying around for a diff. I am just asking if a Comptech Diff will handle the launches with DRs and spraying at 6k
Old Jul 24, 2008 | 07:49 AM
05TurboS2k's Avatar
....uhmm how about some hp numbers?
a 75wet on a otherwise stock S2K?
Dude. I launch a turbo car and my buddy makes 425whp and launches his REALLY hard clutch delay removed, chirping into 2nd hard as well on a bone stock diff even, no issues.
The main thing were talking is the hook-up, figure if he can get away with that on sticky street tires w/ low psi you outa be able to get away with drag radials and a upgraded diff.
oh just remembered what tires he was running if that helps. Nitto 555's w/ low pressure.
Old Jul 24, 2008 | 07:52 AM
Tjs S2k's Avatar
Yeah basically stock s2k on DRs and spray, you know , the typical bolt ons, I,H,E,Tune, Etc. would you guys recommend any good street tires that will hook up pretty well!?
Old Jul 24, 2008 | 08:10 AM
Blacknot's Avatar
That makes no sense. Why only spray in 1st and at 6k? You can spray a 75 all the time. If you wheel hop it at the track it will break the diff.
Old Jul 24, 2008 | 08:20 AM
Spec_Ops2087's Avatar
Get an inlinepro diff kit or don't bother at all.
9/10 people cannot launch the car on DRs, nos, etc, etc while keeping the stock diff in tact, a comptech diff is not much of an upgrade over stock unfortunately.
If you don't have money for the IP kit, then your not going to have money to replace the axles / stock diff again and again when they do break.
Old Jul 24, 2008 | 08:25 AM
Tjs S2k's Avatar
not only first, I meant Im going to start spraying in first, should I wait until 2nd? What are some decent tires then if you guys think DRs are bad? I hit a 1.9 60ft on stock gearing and just an exhaust, but missed a shift so I slowed down. I am a decent driver. My best was a 13.9@96 with a 2.055 60ft on 109 degree heat index. I think I could handle a 75 shot.
Old Jul 24, 2008 | 08:31 AM
05TurboS2k's Avatar
no he's saying why are you waiting until 6k to spray? That means your probably sliding the clutch until you get to near 6K? Clutch won't last long, but thats the only way your going to get decent times because the motor makes no power down low.
This is one of the reasons the S2K is USELESS FOR DRAG RACING. IMO
In general spraying in low rpms makes for massive stress on the internals because of TQ not HP. The lower you spray the more TQ your making and stressing the motor. HOWEVER 75 isn't a lot and he feels you can spray that across the band. I'd say 4K to be safe and that's not AS bad on the clutch wear, so slip the clutch till your hooked up and at 4K then spray until your run is done.
That's just my 'interpretation".
