Nitrous oxide on a 06+
Old Sep 30, 2010 | 06:21 AM
lestat15's Avatar
Default Nitrous oxide on a 06+
can one provide me with info, a link, or just some words from the wise on if adding a 50 shot to a 07 S2k is a good idea. It is deffinately something i am considering later on in life as a "you might think you have me but i have a trick up my sleave" add on. Just want to know the ups and downs .. and i have searched with alot of good knowleadge now but nothing on if it is a good idea to do it on a 06+ !!!
Patrick
Old Sep 30, 2010 | 08:00 PM
s2k dre's Avatar
Dont waste ur time with a 50 shot. U can run a 75 shot with a stock ecu no problems. Just get a wide band. Theres really no good diy links on here so the 06+ is the same as the older ones. Alot of guys like to use tps switches and window switches because they're nitrous noobs. My kit is all mechanical.
Old Oct 1, 2010 | 05:08 AM
lestat15's Avatar
one of the big reason i ask is how do you get around the DBW with the throttle switch ???
Patrick
Old Oct 2, 2010 | 10:50 AM
s2k dre's Avatar
U could use a micro switch! Mine is mounted under the gas pedal. It will work just like a thorttle cable. I dont see why it wouldnt work.
Old Oct 2, 2010 | 10:51 AM
s2k dre's Avatar
The only difference is that ur throttle doesnt open unless the car is running. I can open mine anytime, thats the only difference.
Old Oct 2, 2010 | 11:08 AM
s2k dre's Avatar
I forgot that u cant mount a micro switch under the pedal because the dbw pedal assembly is different than mine. U just need a tps switch thats the best way for an 06+ s2k.
Old Oct 2, 2010 | 05:33 PM
lestat15's Avatar
and about the fuel since i would like to run a wet set up .. just cut in to the stuck line put a T on it and there you ??? just trying to make this as painless as possible and know as much as possible !!
Patrick
Old Oct 2, 2010 | 05:57 PM
s2k dre's Avatar
Patrick
Yes u can cut the rubber feed line. Im using an inline pro rail and using the front port to feed fuel to the solenoid.
Old Oct 2, 2010 | 06:07 PM
BatmanCR's Avatar
I used a WOT/RPM Switch on my 08.. I actually have the kit for sale and it was a very clean and quick setup on the 75 shot.
Old Oct 2, 2010 | 06:09 PM
s2k dre's Avatar
Single fogger wet kit?
