Nitrous storage
Old Apr 12, 2010 | 06:58 PM
hariku821's Avatar
Default Nitrous storage
During the summer do I need to remove the tank from the trunk and bring it in? At what temps should I start to worry?
Old Apr 12, 2010 | 07:25 PM
PsykotiK's Avatar
leave it out.. its how you keep good pressure in the bottle.. pretty common sense.. and the tank wont reach thech the 3000 or 5000 psi pressure limit.. i forget what it is.. but it wont be bad to keep it outside in the car
Old Apr 12, 2010 | 08:27 PM
D1sclaimer's Avatar
Unless you have a F-body with a hatch where the sun is gonna hit it all day, you will be fine.
Heres a chart with bottle temperatures and what the pressure will be. If the bottle is out of the sun in your trunk, you can assume the bottle temp will be around the outside temp. You're burst disc will rupture and release the contents at 3000psi so your bottle would have to get pretty hot. Optimal nitrous pressure is around 1050psi-ish.
Bottle Temp °F Bottle Pressure (psi)
-30 .................... 167
-20 .................... 203
-10 ................... 240
0 ................... 283
10 ..................... 335
20 ................... 387
32 .................... 460
40 .................... 520
50 .................... 590
60 .................... 675
70 .................... 760
80 .................... 865
85 .................... 950
97 ................... 1069
niahuynh
Nov 11, 2011 12:56 PM
detailersdomain
Feb 13, 2010 01:10 PM
espelirS2K
Apr 24, 2009 04:37 PM
Prolene
Dec 9, 2004 06:05 PM
