nordskog performance gauges
Old Dec 17, 2006 | 06:16 PM
Hot.Damn's Avatar
Default nordskog performance gauges
hey guys i was looking at the nordskog gauges(D7015 Boost Pressure Gauge , 0-15 psi) my question is do i need to buy the sender and output relay or is that only if i want to use those functions?
thank you for the help
linky
http://www.nordskogperformance.net/product...etail/d7015.htm
Old Dec 17, 2006 | 06:46 PM
batikan's Avatar
why would you buy those?? i mean of couse it is your decision but they look just like the Autometer Sport-Comp which are less than 1/2 the price
Old Dec 17, 2006 | 06:56 PM
Hot.Damn's Avatar
lower boost reading, autometers are around 30psi for the most part. i was also looking at the digital from nordskog. i want to be able to see my boost clearly it would be hard to see little movemnets of the autometer
Old Dec 17, 2006 | 07:26 PM
batikan's Avatar
i see. well i am using the 20psi autometer boost gauge
Old Dec 17, 2006 | 08:11 PM
Venomous S's Avatar
The sensors on the nordskog gauges aren't all that great.
Always had problems w/ the sensors specially with the oil pressure and fuel pressure. had them replaced at least twice. Vibration killed the sensors in a matter of 5 months or less.
And that is why i switched to FJO.
Old Dec 18, 2006 | 05:39 PM
revhi's Avatar
No probelms with my boost gauge for the past 2.5 years.
Old Dec 18, 2006 | 06:38 PM
pushin9's Avatar
My suggestion is to make sure the gauge is in stock! I ordered 4 of their gauges and the one that wasn
Old Dec 20, 2006 | 01:54 PM
AusS2000's Avatar
You need the sender or you won't have a signal to display.
You only need the relay if you plan to use a warning device like a light or beeper.
Old Dec 21, 2006 | 09:13 AM
Jano's Avatar
I looked at and almost ordered a couple of their digitals. I just wish that it indicated in tenths. Not that a dial gauge is more accurate, but for some reason it bothered me that if you were seeing 5.0-5.9lbs it would still just sit on "5".
Cyberdyne's read in .1 increments but look a little cheap and for some reason, they don't make an oil pressure gauge that reads > 80psi.
Though they are probably the least sexy lookin of just about any gauge, the SPA duals have a very nice set of features for the money.
Revenge
Feb 23, 2010 10:52 AM
Casas
Jan 4, 2008 05:12 AM
jareds2k
Apr 23, 2005 06:33 AM
scs2000
Nov 12, 2002 03:10 AM
