NOS question?
Originally Posted by MIKI2007,Apr 25 2008, 01:25 PM
... how safe is to spray 75 shot... and what kind of system will you recomend...
MIKI
MIKI
Bottle heater, blanket, safety switches, etc all add up quickly. If you have a stand alone ignition then a dry shot with the wet added in at the injectors. If you are running the factory ecu then a wet shot. I would certainly start out slow (30 or 40 shot) and make sure it is working correctly before upping the shot. High octane racing gas is a must since you can't retard the timing. Nitrous only allows the fuel to be utilized and you must add the fuel or go lean.
The f20c piston design is not ideal for nitrous. A go lean situation can easily melt a piston.
CF bottles weigh less and hold more (12.5 lbs) than the 10 lb aluminum bottles.
