not starting when hot!
Old Apr 5, 2010 | 11:05 AM
hondabim's Avatar
Default not starting when hot!
hello,
when the car is cold it will start noproblem. but when it is hot the car will just crank
and not start. if i wait 10-15 mins the it will start.
did any of you guys have this problem, i do have a AEM 1052,
thanks
Old Apr 5, 2010 | 11:10 AM
camuman's Avatar
needs to be tuned better.
Old Apr 5, 2010 | 03:50 PM
dsddcd's Avatar
Sounds like you are not getting enough fuel try modifing Crank Injector Time Table. Start by increasing the Raw value as you increase the throttle Position then try starting the car at differnt Throttle precentages until you can get it to start easily. If it does work you will need to go back and modify your fuel table, warmup enrichment, air temperature trim........ depending on how it was all originally set up.
Old Apr 5, 2010 | 04:43 PM
zoomspeed05's Avatar
This was happening to me on my accord and It was the fuel main relay
Old Apr 5, 2010 | 05:40 PM
dsddcd's Avatar
??? That is strange how did you get it to run at all? Did it have an AEM EMS?
Old Apr 5, 2010 | 06:25 PM
96-EJ6's Avatar
What injectors do you have?
Old Apr 6, 2010 | 10:14 AM
hondabim's Avatar
750cc,,
Old Apr 7, 2010 | 05:23 PM
hondabim's Avatar
any one !!!
Old Apr 7, 2010 | 05:46 PM
dales2000's Avatar
[QUOTE=dsddcd,Apr 5 2010, 08:40 PM] ??? That is strange how did you get it to run at all?
Old Apr 7, 2010 | 06:26 PM
dsddcd's Avatar
Originally Posted by hondabim,Apr 7 2010, 08:23 PM
any one !!!
Did you try working with the tune?
