Not sure what is wrong need help!
Any help would be greatly appreciated!! I just had a ct supercharger installed and tuned this week. The tune was actually performed yesterday. The car ran and felt great all day yesterday and I proceeded to drive it down the jersey shore for the weekend. When I woke up this morning to get coffee it started very rough. It sounded like Subaru!! I thought maybe once it warmed up it would go away but it didnt. Then the check engine light started blinking! Also the air/fuel gauge did not look like it was reading anything. If anyone has advice I would really appreciate it. I am now two hours away from home and stuck.
Thanks
Greg
Thanks
Greg
thank you for the responses!!! So I waited about 10min then started the car again and it was idling fine.Tthe only thing was that the check engine light was on. Took it for a ride and it felt perfect. Floored it a couple of times and the boost and AFR readings were right where they should be. I have started it about 5 times since and no problems. I guess my question is do i have to worry about the check engine light?? Will it just reset itself after awhile? Or could there be something else wrong? Thanks again guys!
There were just two lines across. Wasn't putting out any numbers. When I drove it around the block it would read 17.5-18 for a couple seconds then back to the two lines. Since then it seems like the numbers are right were theys should be. Thank you for the help!
