Novi1500
Old Jan 10, 2012 | 12:05 PM
mrscbw's Avatar
Default Novi1500
Anybody running Novi1500? Does this share the same bolt pattern as the 1000? There was one guy who ran it but I wanted to see if there are others using this blower. Chime in if you're running one!
Old Jan 10, 2012 | 04:08 PM
dsddcd's Avatar
Look up ILoveMyHonda1984 (Joey) him and one other in Australia are the only ones that I know that have done the swap.
https://www.s2ki.com/s2000/topic/918...by-joey-butel/
Old Jan 10, 2012 | 04:51 PM
s2000Junky's Avatar
Different bolt pattern on the 1000. Current 1220/1200/1500 are the same.
Old Jan 10, 2012 | 06:02 PM
donaldmejr's Avatar
True on junky
Old Jan 10, 2012 | 07:44 PM
vduber's Avatar
I could deff be wrong but I thought the 1200/1220 plate needed to be moddified for the 1500?
Old Jan 11, 2012 | 06:45 PM
donaldmejr's Avatar
SOS 1200/1220 plate is a pnp for the 1500
Old Jan 12, 2012 | 04:09 PM
RT-B2's Avatar
Using a 1500, had a 1200 not too long ago.
Old Jan 12, 2012 | 05:41 PM
soulicious's Avatar
How much boost you running? Any dyno sheets available?
Old Jan 13, 2012 | 05:49 AM
camuman's Avatar
I wish more people would do this. The motor is crazy efficient. Needs more air then a typical 4 banger.
1500 + fmic + e85 = straight nasty setup.
Old Jan 13, 2012 | 09:30 AM
s2000Junky's Avatar
1500 + A/C + (dual stage) single pre TB + multi port water/meth injection... priceless
