NY State Inspection OBII w/ AEM, SoS
I apologize if this a beaten dead horse, but it took 5 weeks and as many missed Events, to work my way through this. The process takes about an hour each way after the first set up. I hope some of you can use it
If Secondary air pump is removed go to IZZE ENGINEERING and order both the Evap Emulator and the Air Pump Emulator.
1) Go to Junk Yard and get the Injector clips and a few inches of wire from a "K" series Engine.
2) Install Emulators, be sure to solder connections.
3) Remove 1000 Injectors Install OEMs.
4) Install OEM injector Clips with plugs or other good connector so that they can be exchanged easily in the future.
5) Install OEM ECU
6) Remove Blower Belt.
7) Drive 20 miles.
8) get sticker
9) Reinstall good stuff.
5) Install OEM ECU
7) Drive 20 miles.
8) get sticker
jwfisher
Jan 24, 2017 05:20 AM
camuman
May 4, 2009 07:46 AM
