Oil and coolant plumbing
Old Sep 13, 2007 | 10:47 AM
TheCarGuy2021's Avatar
Default Oil and coolant plumbing
I've started piecing together my gt35r setup and was wondering if someone could point me in the right direction for the turbo plumbing. What sized lines, lengths, fittings, flanges, etc. Everything I would need to do the oil/coolant plumbing. Thanks!
Also, I'm looking for a cheaper alternative oil filter relocation than Ultimate Racing's kit.
Old Sep 13, 2007 | 12:45 PM
s2guru's Avatar
i just bought my AN kit for my gt35r
you need
2 14mm-1.5 to AN 6 fittings
2 AN 6 90d
7 ft of steel braided hose
this is going to tun you $70
now for the oil return line:
GT series flange with gasket
the little solder bug -An 10 bug for the oil pan
-AN 10 45d
-AN 10 90d
1 ft steel braided hose
NPT to -AN 10
thats goign to run you $50
this is the oil relocation kit i'm using.
LINK
Old Sep 13, 2007 | 06:25 PM
Does that oil filter relocation kit work well, how is the quality? I like the oil pressure gauge option, would work well with my AEM oil press gauge.
Old Sep 13, 2007 | 06:49 PM
s2guru's Avatar
the quality is top notch. i don't see why it woul not work. i have the defi oil press sensor.
you can run the oil feed line and any sensor from that oil relocation kit.
NOte: i haven't install the oil relocation kit. i will be using a oil cooler with this kit too.
Old Sep 13, 2007 | 07:03 PM
Ty.'s Avatar
Ty.
he is running a GT1 manifold, so he will need a longer oil drain hose than you have mentioned. Also, why are you using a -6an feed line? That is huge for a turbo feed line
-Ty
Old Sep 13, 2007 | 07:29 PM
Care to chime in TY? I just need to know everything I need for coolant/oil pickup/return so I can just take a trip down to Summit and get everything in one trip. I'll be running a lovefab gt1, 4" dp, and gt35r.
What flange do I get for the oil return?
What size ss lines and how much?
What size fittings/hose ends?
Can I use my Vortech tapped pan?
I ordered that filter relocation kit, but what size fitting fits into the supplied oil feed on it?
Old Sep 13, 2007 | 07:34 PM
Ty, why you not on aim?
Old Sep 13, 2007 | 07:36 PM
Ty.'s Avatar
Ty.
For the oil feed, i would run a -3AN line, with a restrictor inline as well. I'll find out the restrictor size for you, i may even have one here i can send you.
For the fittings and length, you will almost have to take a piece of string or wire and mock up what you think the oil feed/drain is going to look like, and then measure it. I would order a little longer than you think you'll need though, just to be on the safe side. As far as fittings, same thing... You'll need to check out what angles you need (straights, 45's, 90's, etc..) and go from there.
You can use your vortech tapped pan, yes.
-Ty
Old Sep 13, 2007 | 09:06 PM
s2guru's Avatar
-6 an is for the cooling lines.
i'm running the lovefab v1,
HERE you can get the oil feed line kit.
Old Sep 14, 2007 | 11:50 PM
roi's Avatar
roi
Where would I connect the water lines to ?
Pictures will be great
